Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is all different flashing colors
I have a Sony Wega Trinitron 32 inch. The tv was working fine until today when the picture suddenly turned all different flashing colors. The tv does not show the actual colors of the programs were watching but it just flashes all different colors. What might be the problem?
    Problem Solver:
  • 4 Answers
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Posted on May 07, 2008
Sony trinitron srs wega 36 inch colour is going blue gone already is it worth fixing?
hello eightythreem!
some pro's and contra's...
Trinitron tubes are the best ever built picture tubes - long life, best contrast and sharpness, brilliant colors, etc thou u never get with any modern lcd screen. otherwise the big form factor is uncompareable with todays thin screens. also the brand itself and in your case the wega model is a name on its own high standard. anyway i would recommend you to let your tv check by a local service cause it sounds like a electronical problem - let them tell you how much aproximately fixing will count - before they repair it - so you still can decide is it worth or not. hope to helped a bit.
regards
Feb 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron 32 inch widescreen only gives slight flash when you turn it on but sound is working. no picture just sound. picture worked once since this started happening and then went off again. Any...
there might be a problem with the connection of the screen to the motherboard or the wire that connects it might be the fault. but there could be a burnt fuse or components.I would suggest letting a tv tech have a look good day sr
Nov 23, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My sony TV trinitron wega 42 inch picture is red. Is there any solution to remove the problem?
The problem with your TV trinitron wega is at the color adjustment section. It is located at the color board mounted at the back of the picture tube. There are variable resistors that represents the color pattern in the picture tube. Adjust the red color to low level to lower the red color.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32 in. Sony Trinitron stand by light keeps flashing
has a sony 41" REAR PROJECTION TV THE STAND BY LAMP IS BLINLING HAS RESET IT , NOTHING. HAS NO PICTURE NO SOUND
Jul 31, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture color is distorted.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Jul 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Problem with 1999 Sony Trinitron Wega 32 inch TV
sounds like the tube has gone any good tv repair shop will be able to replace it cheapley.
Mar 08, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony trinitron 32
Hi, tubes getting tired, band-aid fix you can do is remove back of set and turn up(clockwise) the screen control( small black plastic control mounted on side of flyback transformer, do not turn the knob marked focus) until you see a whole bunch of white lines across the screen, then turn same control counter-clockwise until all the lines go away, try several different channels to be sure all the retrace lines are gone, you`ll get up to 1 year more use out of it, than she`s done, good luck, BMW Rider
Dec 10, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
329 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
