Hi in the headset there is a ballbearing set for the top and bottom. Insert fork through position. From the top you can slide the handlebar over the extension. Make sure that you align correctly. Then fasten with the allen key.
Hi, Max if you have a minor accident, lay your bike down and the front end gets 'TWEAKED" where the front wheel is going in one direction and your handlebars are going in the opposite direction, despair not, there is a quick fix.
1. If your handlebars are turning right turn the front end all the way to the right making contact with the fork stop. Find the 10:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the left fork stop and find the 2:00 o'clock position and give it a soft kick.
2. If your handlebars are turning left turn the front end all the way to the left fork stop. Find the 2:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the right fork stop and find the 10:00 o'clock position and give it a soft kick.
Continue the process until you are comfortable with the alignment. It's always a good idea to retorque any accessible handlebar riser bolts as well as the upper and lower fork clamps to proper book specs.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected]. Good luck and have a wonderful day. https://www.youtube.com/watch?v=pNEmOqY02EU http://www.mediafire.com/file/ixi9v51eb2kb99u/1998_Harley_Dyna_Service_manual.pdf/file https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc https://serviceinfo.harley-davidson.com/sip/service/document/6300 https://www.6ya.com/
You need to hammer the cap on. The tube with open ends fits over the cap and lets you hammer it on. To make it work, you need something to hold the other end, like a block of wood, or I found a hockey puck worked perfectly. Assemble the rear wheels, then turn the cycle on its side with the cap end of the axle down. Put it on the block of wood or the puck, and then hammer on the cap with the help of the tube. Now if you can help me get the handlebars on, I'd be eternally grateful. Problem is the spacers seem to be too big to allow the fork into the slot in the handlebars, and without them, there is nothing to screw into to hold the handlebars.
You need to take the entire throttle control assembly off the handlebars and disconnect the cables from the carburetor. Check each cable for free movement. If you have a frayed cable, you will never get it to work correctly so check the cables. Now when you go to put the assembly back together make sure you put some thin grease on the handlebar and inside the throttle sleeve before you slide it up on the handlebar. Put white lithium grease in the area where the cables connect to the throttle sleeve the bolt the two halves of the switch housing together. Slide the switch and throttle assembly all the way up on the handlebars and then back it off about an 1/8" or so. This insures that the handlebar is not rubbing on the inside of the end of the throttle grip.
Loosen both nuts on front wheel. Stand bike straight up, or set bike upside down on seat and handlebars. With fingers on fork and thumb on wheel, pull wheel so it is centered on fork.
Now tighten one nut part way. Keep holding wheel. You may need somebody to help. Then tighten other nut. Go back to fist nut and tighten a bit more. Repeat back and forth tightening until nuts are tight and wheel is in center of fork.
If I understand your question, you put the handlebars into the front steering assembly but they don't attach.
On top of the handle bar is a screw that when it is turned in pulls a wedge shaped bottom piece up. When this is done once the handlebars are in the steering unit, the handlebars lock up and can't rotate or pull out.
If that doesn't answer your question, let us know.
Gary
Take a little trip to www.schwinn.com They have instruction manuals, videos and most importantly a customer service line with someone that can walk you through their specific product.
It should not be that difficult for someone who is not a novice to put the trikes together, something is definitely wrong. Double check on the schwinn site that you have the correct assembly manual and parts list. You still have time, don't panic yet.
The front fork slide in through the head. You must make sure that you have the headset ( a ballbearing assembly) in place. Not rusted. Make sure there is some grease in it .The pin of the fork slips through. The handlebar fits differently depending on the bicycle. Basic models fit directly on. More sophisticated models have a t-piece . There are shorter and longer extensions. They fasten with allen keys.It is actually easy to assemble.
Rear wheel should be already on, put front wheel into forks and tighten nuts or quick release lever.
The handlebars should alredy be attchd to the neck. Put the neck into the frame and tighten bolt or allen head when bars are straight aligned to front wheel. Install seat and any reflectors....follow these instructions carefully cause the manual that comes w/these bikes is junk....Good Luck to you friend.....Tim
Hi, Front end vibration can be caused by front rim/tire out of balance, worn wheel bearing(s), bent front rim, or fork misalignment. Since you recently had fork work done, I would first check the forks for proper alignment, then have the bike on a stand and spin the wheel to see if there is wobbling. To check for bearing wear, while the front is off the ground, try to rock the wheel from side to side. If you can feel or see movement, you will need new bearings. Hope this helps
