Question about Maytag PAV2300 Top Load Washer
Squeaking during spin cycle
I have a Maytag PAV2300 that sounds almost like a small plane is taking off during the spin cycle. I am wondering if it is the belt or maybe a bearing?
  • tucsonjim Jun 18, 2008
    I followed the advice here and removed the agitator from the shaft to see if there was an obstruction under it. There wasn't. Looking to see if there was an obstruction in the "discharge filter" (I could find no such thing), I took off the hoses to the pump and from the pump to check for obstructions. I took the belt off the machine and turned the pump pulley and there was some grinding noise there.
    I found that the pump pulley had slipped a little off the spindle and a corrugated metal strip that holds the pulley on the spindle had worked its way out of the groove and was rubbing against the pump mount flange. It caused so much resistance at one point, the washer wouldn't spin at all. I took the pump off the machine and took the pump apart. I was able to work this strip back into the groove in the pulley and tapped the pulley back on the spindle. The washer works fine now, quiet as can be.
    Note: When replacing the belt, be sure to put it around the pump pulley and motor pulley first. Then lift the motor pulley up (it has a tension mount) and turn the agitator pulley as you work the belt on to it.
  • Jackjd Jul 27, 2008
    Maytag 2003 - top load - sqeaks in spin cycle ?
    Genius:
  • 1,073 Answers
Check the pump there is something in it, it cam be disassembled mark the metal to the plastic with a line across the metal and plastic so you dont have to guess how to realign
Posted on Apr 30, 2008
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
When the washer is in the spin cycle it make a loud squeaking sound
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Maytag PAV2300 Top Load Washer
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Maytag PAV2300 Top Load Washer Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
