Question about Maytag Atlantis MDG8400AW Gas Dryer
Control Knob My control knob won't pull out anymore..any suggestions?
    Genius:
  • 1,073 Answers
Need to repalce the timer part number is 33002854
Posted on Apr 30, 2008
How can I remove the old gear shift knob and install a new one in my 2000 SLS Cadilac
There is either a small 'c' clip on the front/bottom side or it has an iternal snap ring. If it is the 'c' clip you should see a small slot that you can pop the clip out. If it has the internal one, it pulls straight up and off. Warning: Do not twist it, you will break something expensive in the shifter. From the service manual....
Detaching the shift control knob from the shift lever may require a large amount of physical effort.
Do not twist the shift control knob while pulling.
Firmly grasp the shift control knob.
Pull straight up to detach from the shift lever.
Installation Procedure
Align the shift control knob to the shift lever.
Firmly press down on the shift control knob in order to attach to the shift lever. An audible sound will be heard when the internal clip is fully seated.
Here's a video too!...
How to Remove shift Knob Cadillac Seville
Jun 03, 2015 | Cars & Trucks
Simpson EZISET cooktop control knob does not turn
Take some electronics contact cleaner, CRC is best, and spray the knob. It has grease inside that is preventing the spring from popping it up so it turns. You'll need to get a new knob eventually and please don't install it yourself unless you are well versed in working with gas.
May 08, 2015 | Cooktops
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
Temperature control knob not working
HAVE YOU PULLED THE KNOB OFF TO SEE IF IT IS CRACKED?
THEY SOMETIMES DO AND THE KNOB WON'T TURN THE SHAFT
Oct 23, 2012 | Chevrolet Colorado Cars & Trucks
Climate control selection knob is broken The knob would not turn and when I pulled it off a piece of plastic droped out and now the knob turns freely but won't change the settings from AC to defrost or...
If I understand correctly, the same thing happened to me. It might just be the knob, if you can use pliers to rotate the metal piece where the knob connects then either buy a new knob or you could hot glue the old one in place. Just make sure you have it pointing in the right direction if you do.
Oct 08, 2011 | 2002 Buick Century
Is the knob that turn the light on repairable? The oven light is on but would not turn off. The knob just keeps turning...
HI,and a merry Xmas.
Yes it is repairable, it is going to be one of two things.
1--the control knob is cracked or broken causing it to twist round without turning the control.
2--the spindle on the control is broken or loose inside the switch.
Pull the knob off, and see if yopu can turn the switch on and off with a pair of grips or pliers.
This way it will enable you tell if it is just the knob or the switch that is faulty.
Good luck.
Please leave feedback for my suggested solution.
Dec 25, 2009 | DeLonghi Ovens
Temperature control knob turns but doesn't change temp.
the heater control valve is visible through the speaker cut-out; it's at the end of the plastic heater control rod, inside the car - not on the other side of the firewall! It's connected to the valve with a plastic "universal joint".
Check that the valve is actually being turned by the rod. The connection might not be good (pulled apart or broken), and or the valve might be stuck.
Saabreur
Mar 14, 2009 | 1991 Saab 900
Oven does not turn off completely
You should pull the knob off and check that there is a metal liner in the knob itself. These sometimes fall out and the plastic knob does not turn the control properly. Get a new knob at your local appliance store.
Jan 20, 2009 | Ovens
Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
Nov 16, 2008 | Amana Cooktops
Control Knob Replacement
either pull it off or look for a set screw on the bottom. could be a regular screw but most likely an allen head set screw. go to repairclinic dot com for a replacement
Aug 23, 2007 | Admiral AAV7000A
Maytag Atlantis MDG8400AW Gas Dryer Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
