My laptop boots and then shuts off in about 1 min. It does this on AC or Battery. Is the battery dead? or is this an internal problem?
    Genius:
  • 3,587 Answers
Hmmm..sounds like an internal issue, if it's happening on either channel..can you boot up in safe mode(F8) and maybe run a virus scan?
Posted on Apr 30, 2008
Beep problems
Possible faults:
1.The battery has no power.
2. AC adapter loses energy (need test it)
Remove the battery and turn laptop directly from AC adapter. OR, try to turn the battery directly without AC adapter.
if the signals are repeated then most likely have to replace the AC ADAPTERghj,
Oct 06, 2013 | Dell OptiPlex Computers & Internet
Power on of laptop cannot be turn on (samsung)
Step 1:
Unplug laptop from power.
Step 2:
Remove internal battery from laptop.
Step 3:
Plug laptop back in.
Step 4:
Turn on computer as you normally would.
Step 5:
If it starts up on AC power, then battery is dead. Must replace battery.
Step 6:
If still not booting up, then must check the AC adapter for output (use voltmeter). If no output power on AC adapter --> Replace it.
Jan 13, 2013 | Samsung R458 R408 R410 R453 R460 laptop...
I need administrator password for compaq nx6110
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Aug 11, 2011 | HP Compaq nx6110 PC Laptop
My Acer Aspire one notebook ZG5 won't turn/boot on, help?
1. Dead AC adapter
2. Dead battery
3. Broken AC-socket on laptop, so no power is received, and battery is not charging.
4. Dead ON/OFF switch
5. Dead motherboard
Take your computer to a qualified technician, for professional trouble-shooting & remediation.
Jul 19, 2011 | Computers & Internet
Laptop power charging stops and laptop later shuts down and no charging
First you should figure out what caused this problem. Here below are some possible cause:
AC Adapter Problems
If the AC adapter is not working properly, then the charging won't occur at all. An AC adapter, with lower than required voltage settings, will not be able to charge the battery. See to it that the AC adapter matches the laptop battery's requisite settings. A loose wire or internal breakdown, may render an AC adapter useless. Changing the adapter all together might solve your problem.
Acer Aspire 5720 AC Adapter
Power Management Software Problem
Sometimes, the problem is merely with the power management software. This is the classic case, when the laptop charges when switched off, but doesn't when the computer has booted. The software may have gotten corrupted which must be causing the problem. In such a case, go to the device manager section and uninstall the power management software. In case of Windows XP, uninstall 'Microsoft ACPI Compliant Control Method Battery listing' from the device manger section. Take care that you do not install any other AC adapter driver software. Then go for a 'hardware scan', which will automatically identify the battery and reinstall the latest version of the drivers again. That will restore the charging facility of your laptop.
Internal Charging Circuitry Problem
If neither the AC adapter, nor the power management software has a problem, then problem can be with the internal charging circuitry of the laptop. In this case, there is little you can do, other than send the laptop to the manufacturer's service center.
Bad Battery
If you have checked for all of the above, one of the main reasons, which could lead to the problem of laptop plugged in but laptop battery not charging is a bad or dead battery. Run a laptop battery test. If your laptop is quite old, this could be one of the most likely reasons. Get the battery checked from the manufacturer and check if it has exceeded its predicted recharge cycle limit. It is important that you get the dead battery replaced immediately with a new one. Laptop battery troubleshooting will solve the problem.
Hope this will help.
May 09, 2011 | Acer Aspire 5720-4230 Notebook
Acer 5315
Could be the power supply. (Likely built into the power cord). Heat could have been causing it to fail before. Possibly dead now!
Jul 11, 2009 | Acer Aspire 5100-3357 Notebook
My ibm laptop contionusly beeps and says power scource is battery,when i press esc, it boots normally and shuts down in about 15 mins to half an hour
Either:
A. Bad battery
Or
B Bad power supply.
Sounds like the battery isnt charging correctly , the beeping is warning you it is running out of power.
Take the battery out , and boot normally with the ac adapter.
Does it work?
If yes, Get new battery. about 70-90 dollars.
If no. Get new ac adapter. 20-40 dollars.
links to parts
http://www.nextag.com/ibm-a21m-battery/search-html
http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=ibm+a21m+ac+adapter&x=0&y=0
http://www.laptopuniverse.com/product/02K6496-Laptop-Notebook-Power-Supply-AC-Adapter-For-IBM-Lenovo-Thinkpad-A21M-16V-60W-Part-02K6496/LU/36124/productDetails.html
Mar 03, 2009 | IBM ThinkPad A21m 2628 Notebook
Sony PCG-F340 keeps shutting down
Old Sony laptops do this when the battery is dead, or the charging system is below required voltage. A battery with a dead cell (which this sounds like) can damage your external PSU and internal battery/power regulator circuit. Remove the battery (shut down and disconnect PSU first). You can run the laptop forever, without the battery, if you cannot find a battery replacement, or do not like the cost. Obviously, though, the laptop will not run at all without the AC/PSU connected when the battery is removed.
Feb 08, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
