Question about Radio Communications
Good carrier, but no modulation or receive
I have a ge radio that has a great carrier but has no modilation or recive, I have tried different mics and they all have the same change........I found a 1000uf cap that was blown by the audio ic and i changed it with the same thing and their was no change in the problem..........can anyone help me?
  • Anonymous May 01, 2008
    I cant seem to get my radio to receive clearly.
  • theradioguy May 11, 2008
    All the problems with this radio were on the bench, I have used the same test equipment with other radios without any problems, and have since tested other units without problems.
  • 37 Answers
Audio IC is junk, replace it and it will work fine. common problem
Posted on Aug 04, 2008
    Problem Solver:
  • 6 Answers
Some say try new antennas but,I think the major cause is the coax.
I also had a signal problem and did try new antennas,did nothing. Then I find out that the coax they are putting in the newer trucks,like my 2007 is nothing but Junk. You have to start from the source and that is the coax.
Posted on May 08, 2008
My rci ranger wont transmit but it receives great what is the problem
it could be several things......the rf final,bad mic,cold solder joint on the circuit board just to name a suggestion is to find a good local cb shop,if no local shop find one along the interstate hwy most of the time they are located around or near some of the larger truck stops. tell the tech there what the problem is and go from there. good luck !!
Apr 04, 2013 | Ranger Communications RCI-6900F-25 CB...
My Cobra 29 LX receives including the weather but can't transmit
If the relay contacts are closing. You may have blown the output transistor, however a broken wire in the microphone can also create the symptoms you describe. .
you can check by using a #47 light bulb soldered to a PL259 connector as a dummy load. If it lights, the carrier is present, but you may not have voice modulation which will show as differences in light intensity as you speak. If no modulation, the microphone is the first thing to look at.
The relay contacts may also be very pitted or corroded and not achieving continuity.
Feb 17, 2012 | Cobra 29 LTD CB Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here. this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
I have a Galaxy DX 55v cb radio...The problem I am having is that when I key the mic the radio does key up but will not modulate.I have tried several different mic's...I also have trouble receiving but if...
sounds like somebody has tampered inside it , knocking out alignments. There is a resistor and very small transistor near back that controls transmit+receive. I don't know which number resistor it is on your model. I know where it is on Uniden/Cobra models(recommend Cobra 25ltd) Take to Cb shop or service repair place. They may help you. Just buy you a Cobra for cheaper and go with it.
May 01, 2011 | Galaxy Radios DX-55V Base CB Radio
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
Jul 30, 2010 | Radio Communications
I have a Cobra 18 wx st. I am not able to transmit anything on it. I have checked the antenna cables and and all external connections. I receive all the wb just fine but the CB gives me nothing. I tried a...
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike. With the WX band working, the above may not apply.
See if you have a carrier...signal going out, but no modulation. Get your Tech to check the mike wiring/circuitry inside the radio, also.
Jul 06, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
No modulation with strong carrier
sounds like your Audio Output went out......not audio chip....may be your voltage regulator also....your voltage regulator IC is heat you have a schematic?
Jan 23, 2010 | Cobra Radio Communications
I don't have voice, have carrier. Cobra 29 ltd
there are several things that might be responsible for the absence of modulation when speaking into the microphone. a defective mic cartridge, a broken audio or audio shield/ground wire in the mic cable or mic plug or a defective push-to-talk switch in the mic itself, for starters. if all is well here then the amc and transmitter speech stages in the transceiver will have to be considered next. locate and check with a known good mic wired for the radio in question. let me know.
Jun 06, 2009 | Cobra 29 LTD CB Radio
Great TX no receive
broken wire on mic plug, black wire pin 4 0n mic...doc's cb shop ny
Jul 18, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
200 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
