Question about Blitzz Technology (BWA611) Router
Router Thank for your help I am almost there with setting my wireless pass code WEP But i am still having trouble with the following 1. My Key input Hex-ASCII ? 2. Key value ? Thanks Again Vic
  • Viciu Apr 30, 2008
    Thank you
    Guru:
  • 1,342 Answers
ASCII is easier to use. Hex numbers can get pretty long.
Use this little tool
Key value is pretty much up to you.
Posted on Apr 30, 2008
Hello, I'm trying to connect my wii wireless and it keeps giving me an error code 51330 "unable to connect to the Internet" could you tell me what it means? Thank you.
Error Code: 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
Are you using WEP or WPA security on your router?
  • Log into the router using the default IP (consult your router's manual for assistance)
  • Locate the "wireless security" section of your router settings and find the WEP or WPA key.
  • If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
  • If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
  • The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
  • If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
  • If you are using WPA, the Wii console is compatible with the following types:
  1. WPA - PSK (TKIP)
  2. WPA - PSK (AES)
  3. WPA2 - PSK (AES)
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday)
Feb 27, 2011 | Nintendo Wii Console
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
I am trying to connect my wireless printer to the router, but when it comes to the WEP code, the one I have does not work. Is there a way to reset the WEP code?
Hi glenncj,
Welcome to Fixya. If you need the WEP key or Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Wep Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
You can also reset the router by pressing the Reset button at the back of it for 15-30 seconds using a Pen and a Paper Clip.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 07, 2011 | Linksys Wireless-G WRT54G Router
I cn not find my wep code
Hi bobraywhite,
Try to locate the wep code underneath the router. If you cant find it I suggest trying the following steps:
1. Use the Internet Explorer browser.
2. Type the following IP address in your address bar: 192.168.1.1 , you will get a login window. Your user name can be blank and the password is admin. If you have trouble logging in use the user name: admin, and the password is: password.
3. Click on "wireless" then "wireless settings" or "wireless security." Toward the bottom of the screen look for "Security Encryption (WEP) key," if you see more than one WEP key use the first one listed.
Hope it helps.
Thanks for using FixYa
Bestregards,
Reyjoshua07
Jan 25, 2011 | Computers & Internet
Need my wep key number to add a wirless printer to my computer
Welcome to FixYa! There are two ways of getting the WEP key for your router. Easiest way is to check underneath the router and you will see there the default WEP key. Or, follow these steps for you to be able to get the WEP key set by your ISP.
1. Connect the computer directly to the router.
2. Open up a browser and type 192.168.1.1
3. It will ask for a username and password,type admin as the username and admin as the password, if it did not push through,try password as the password.
4. Once you have the GUI ( Graphical User Interface ) click on Wireless Settings.
5. Click on Basic Security Settings.
6. You will be able to see there the wireless key which is the same as the WEP key. You can go ahead and personalized that security key as well.
Hope this will help...Thank you for using FixYa...
Dec 01, 2010 | Westell Wirespeed VersaLink...
Error code 51330
This error is faced by many other users too. There is a procedure you have to follow to solve this error.With this procedure some gets solved and some does not. In that case the Nintendo support center needs to be contacted for reset internally.
The procedure is as follows:--read it carefully and completely and then follow it properly.
Error Code: 51330
WPA - PSK (TKIP).
WPA - PSK (AES).
WPA2 - PSK (AES).
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
If the Mac address filter was disabled, then continue troubleshooting.
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
Check Nintendo's router info for special notes, if available, for your router.
Click here to go to our Wireless Router lookup page.
Use the drop-down box to select, if available, your router manufacturer.
Sep 01, 2010 | Nintendo Video Game Consoles & Games
When I try to connect to the internet this comes
That means it's not connecting to the wireless router. You need to go on a PC connect to the router. It is usually 192.168.1.1 or 192.168.0.1. Once you login (default username and pass varies by router but "admin" and "admin" is my first guess). Go into the wireless settings and make sure that:
1. It is being "broadcasted" and not "hidden"
2. You are using the right encryption method your router is at (WEP, WPA, etc)
3. Make sure you have the correct WEP code
Hope this helps,
BReady
Mar 27, 2010 | Nintendo Wii Console
I gorgot my wep passpphrase
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 28, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
Error code:51331
Jul 02, 2008 | Video Game Consoles & Games
Blitzz Technology (BWA611) Router Logo
56 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
Tre Elkins
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
