Codes for tv
Lost my code sheet. have jensen remote JER 422need code or proceedure to activate memorex tv model 16-229
    President:
  • 2,712 Answers
0150, 0154, 0016, 0056, 0178 are the codes you can try.
If none of the codes work then there are two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash radidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programing your remote can be found here: http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 30, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    rating under my solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Lost remote need code for universal remote
since most of the disney TVs are manufactured by memorex company ..... from your universal remote control's manual check the codes for memorex brand & try it .... if you don't have manual for your universal remote then from this link http://www.remotecentral.com/features/remotes.htm identify your universal remote & in that check codes for memorex brand & try it .... while searching answer for your question i have found that many people have same problem that is code for universal remote ..... but they never got right answer ......... & also neither same original remote control nor equivalent remote control is available (spare ) ...... so in case if you don't get right code then consider selling of this TV & buying new tv ...........
Oct 28, 2011 | Disney Lightning McQueen TV
Lost remote tried universal remote it would not work
Hello
You just buy one Philips Universal Remote control Model No: [CL 034]. Your Jensen TV is lited in its codes. Codes and proceedings are given.
0002 0502 0914
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Dec 14, 2010 | Jensen TS2750J TV
I need a remote
New universal remotes come with a code sheet that should cover most every brand TV ever made. I recently got a Phillips brand universal remote from Wal-Mart and set it up to operate a 15 year old JVC TV.
Nov 20, 2008 | Memorex MT1127 TV
Need memorex mt2274 tv code for comcast multi-control remote
I've had the problem this morning. Memorex codes are 10154, 10463, 10150, 10178, 10016, 10179, 10877, 11570, 11911, &11920. These are for the remote that is for the smaller digital box. I tried them all, and 11570 works for my model - the power shuts off, but the comcast remote will not turn the power back on. Volume works ok.
Jim
Oct 14, 2008 | Memorex MT2274 27" TV
I have lost my tv remote for my syphonic tv
One website gives instructions on how to use the AUTO CODE SCAN feature of your remote, even if you don't have the code numbers. Take the following steps to access this info.
Step 1) Type REMOTECODELIST.COM into the Google searchbox, and click on GO or SEARCH.
Step 2) Once you are on the website, scroll down the page until you see JENSEN in big red letters, on the left hand side.
Step 3) Look under JENSEN for SC-540 ( in purple letters), and click on SC-540.
Step 4) Look on the right side of the page for instructions on how to do an AUTO CODE SCAN.
Hope this helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 15, 2008 | Symphonic ST420FF 20" TV
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Lost code sheet for RCA remote RCR450C; Durabrand TV DU 1901
Los codigos de tv admiral son los siguientes 001,046,047,083,095,173,191.,espero que te sirvan.
Mar 08, 2008 | Durabrand DU1901 TV
Universa remote codes.
I used Memorex code 135
Jan 20, 2008 | Disney DT1350-P 13" TV
Universal remote
the universal remotes work fine in any tv, but limited to basic funcion, if you whant full funcion one, go to, www.remotes.com or call 1-800-remotes..good luck
Aug 10, 2006 | Jensen TS2050J 20" TV
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
Electro Med Services...
