Question about Audiologic DVCR-251
MY KARAOKE MACHINE
HI!
MY KARAOKE MACHINE HASN'T BEEN USED IN A MONTH AND WHEN I TURN IT ON THE POWER IT DOESN'T TURN ON. SO I WAITED A FEW MINUTES AND I TURNED IT ON AND IT WORKED. SO I TURNED IT OFF AGAIN AND SWITCHED IT BACK ON BUT IT DIDN'T WORK. THE TYPE OF MY KARAOKE MACHINE IS A AUDIOLOGIC KARAOKE MACHINE THAT I PURCHASED 2 YEARS AGO.
COULD YOU PLEASE HELP ME?
SINCERELY,'
CONFUSED
    New Friend:
I have the same type Caraoke machine that turns on but it does not play the CD....
Posted on Dec 26, 2012
2 Suggested Answers
SOURCE: audiologic dvd 108
with in the Speaker from the setup play with those settings,
this system is terrible!
Posted on Jan 15, 2008
Looking for an instruction manual for a ultimate kdx 3000 karaoke machine
Hi I have a ultimate kdx 3000 karaoke machine with no remote Not sure if their is any hidden menus as even when the mic is turned up full the music drows the vocals any help please ????
Aug 12, 2013 | Audio Players & Recorders
My karaoke machine will not play CDs
the only suggestion I can offer is clean the laser lens with a Q-Tip and rubbing alcohol gently and allow several minutes to dry, if that fails! the whole assembly will need to be replaced.
Mar 15, 2012 | Venturer CD-2160 Shelf System
Hello, We have just transferred our AWA DVD 5.1 Home Theatre System for improved sound to our television from our home theatre projector. I was wondering if there is any way of turning off the sleep mode...
Just go into the device sleeper mode and now used the romte pushes the SLEEP button on the remote a few times to make sure the SLEEP mode timer it is to be turn off.This problems should be solved.
May 09, 2011 | Televison & Video
Once in a while my grinder W7-125 doesn't start, then I'll have to losen the carbon brushes, put them in again, and now and then the grinder starts again and now an then I'll have to repeat...
I would look at the switch action sometimes the rod doesn't want to fully engage the actuator. Also look for debris that might be in the brush area. And lastly look at the brush shunt/spring to ensure there are no restriction to the shunt (wire) that will not allow it to easily move in the brush holder. The brush should slide with no pressure in the holder. Let me know if you need more assistance.
May 08, 2011 | Metabo W7 125 Angle Grinder 5" 9,000 Rpm...
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
Audiologic DVCR-251 Logo
450 people viewed this question
Top Audiologic Televison & Video Experts
Electro Med Services...
Are you an Audiologic Televison and Video Expert? Answer questions, earn points and help others
