Question about Refrigerators
I HAVE 26 CUB REF. FREEZEER ON TOP. A FEW MINUTES AGO THE REF. STARTED TO MAKE NOISE. IT SEEMS LIKE ITS COMMING FROM THE TOP ABOVE MY ICE CUBE MAKER. WHAT CAN I DO BESIDE PULL THE PLUG?
  • lynlee103 Feb 05, 2009
    High pitch squeal with GE side by side fridge. Sound goes away when opening doors
  • 828 Answers
If it is a high pitch sound it may be the fan motor bearings. You will hear the squeal even with the door closed. This problem is solved by replacing the fan motor.
Posted on Apr 30, 2008
Popping noise
it's the aluminum defroster coils cooling after a defrost cycle.
a padded aluminum foil-covered mat installed behind the defrost heater in the back of the fridge is a fix at least for Samsung I know.
Jan 07, 2018 | Magic Chef CTB2125 Top Freezer...
Timming chain noise
The noise your hearing is comming from an aluminum timeing chain guide on the drivers side of the timeing chain. My truck had the same problem. The noise first started when the engine was started and then within seconds went away. I drove it for about a year not knowing what the noise was comming from. A few weeks ago the noise got very loud and the truck stopped starting eventually. A few hours ago I pulled the front of the motor off to replace the timeing chain and my guid was broken right off and laying at the bottom of my oil pan. You can remove the two allen head bolts that hold this guide in place and run the vehicle without the guide. Problem solved and no more noise.
Nov 27, 2010 | 1996 Nissan Pickup
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Adjusta ice cube maker not working
Have you checked if water is comming out the tubing before hookup? A valve may be close...
Dec 10, 2007 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
