Samsung hln4635 makes buzzing noise when powered on
    President:
  • 2,712 Answers
Try lowering the backlight to less than 10. This seems to be a known issue with this model. It could be the cooling fan, and usually the noise is higher when the picture is dark or has a high contrast.
If your TV is still under warranty, then the best thing to do would be to get it replaced. If not, you may need to call in a qualified technician to look into this.
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 30, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    rating under my solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Samsung rfg297aars making buzzing noise
Have you got anything on top of your Samsung if the answer is yes, then that is where it is coming from move everything a part from each of the items make sure they are not touching each other okay.
Dec 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
Why is their a buzzing noise when my flatscreen Samsung tv is on
Usually the sound is coming from the power supply board in the TV--a transformer is vibrating hard enough to make it--had a lot of new ones in warranty that worked perfect but had a buzz---replace the power supply board and problem usually is fixed.
Apr 10, 2012 | Samsung Televison & Video
Samsung 40" LCD LE40m87bd making buzzing noise
is it hooked up to an extension cord or a cable box?
Oct 20, 2011 | Samsung Televison & Video
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Motor power
you need your power supply repaired. buzzing sound is a bad disc capacitor. blank picture can be bad mofsetts, invertor and bad capacitors.
Dec 27, 2009 | Samsung 732N 17" Monitor
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Buzzing noise
You need a new color wheel.  Partstore.com is a good place to get them.
Check out:  http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jun 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Ive just purchased a samsung 50 inch plasma which makes a buzzing noise like a fridge. i already had a phillips 42 inch and this made hardly any noise. is this normal as its driving us mad.
This unit should not make a noticable buzz. Bring it back for an exchange. There is a problem with the switch mode power supply.
Dan
May 07, 2008 | Televison & Video
Plazma TV buzzing noise
I have the same problem I can hear buzzing over the volume of the tv into the 30 range. I've had a tech out 3 times and he's coming out for a fourth. He's changed to power supplies and is bringing the 3rd next visit. From what I've read it has either to do with power supplies or grounding strips.
Jan 18, 2008 | Televison & Video
Televison & Video Logo
320 people viewed this question
Top Televison & Video Experts
Electro Med Services...
