posted by sandax on Apr 30, 2008
I bought a 25"Toshiba TV screen( Model NO. 2560XHE ) from a friend who was going finish some three years ago.Just recently I encountered a problem with this tv screen. There is no indication of picture display on the screen- a complete black out. Upon depressing the switch of the screen, a red light comes on, and after a while a green light (LED) comes on and off. Can you tell me what could be a possible cause of the problem with my TV please ?
Provided by LOGITECH STAFF
Solution #1
posted on Apr 30, 2008
From the symptoms you describe, it seems the high voltage flyback
autotransformer has failed along with the horizontal amplifier (they
are slaved to each other). This could have happened during the moving process. The sound comes from the flyback
unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced.
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Cheers!
IrishDruid
Comment by IrishDruid, posted on May 03, 2008
Just wanted to inquire if your issue is resolved, or if there is anything further I can do to assist you…
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating under my solution. I would be very grateful for your show of appreciation.
Cheers!
IrishDruid
Cheers!
IrishDruid
Comment by IrishDruid, posted on May 31, 2008
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
IrishDruid
- "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
- "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
- "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
- "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
IrishDruid
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Standard Televisions
Email this problem
Email this problem
This Problem Also Relates To:
GE 13GP341 13" TV
GE 27GT271 TV
GE 27GT270 TV
Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV
Can you Help with these Standard Televisions problems?
Apex Digital AT2708 27" TV
Problems with Apex Digital...
Problems with Apex Digital... Answer This...
RCA TruFlat 27F520T 27" TV
Can't program remote/sensor...
I have a truflat 27f520 bought... Answer This...
Repair Service
Find Standard TV Repairman Near You:
