Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer wont start!
When I hit the cycle start button, the door lock and wash lights turn on, shortly followed by the rinse and final spin lights. All the lights will remain on and the washer will not start. If anybody has a solution to my problem I would really appreciate the help!
Thanks,
Jerad
    Genius:
  • 3,587 Answers
Sounds like you have a very unhappy control panel..unplug it, wait 5 min..and then plug it back in..if it does not reset, then you may want a repair job, no?
Posted on Apr 30, 2008
  • Patrick Michaels
    Patrick Michaels Apr 30, 2008
    are you in the mood to do this repair yourself?
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Whirlpool front loaded getting stuck in wash and rinse cycle
You can remove the top cover of the unit and put your hands towards the door lock and just hit fair enough to get release the lock mostly it will open if not means just break the lock and replace it since if you are technician it will be easier for you if not kindly call the technician and do the service
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Door lock
Appreciate the direct "Ask Me".
To my knowledge, there are two (2) versions of a Frigidaire ATF6000ES Front Load Washer: a) ATF6000ES1 and b) ATF6000ES0, pls which one do you have?
If something is wrong with the washer, it could tell us the error codes and therefore would give us a general idea where to start the diagnosis. Other than the "Door Lock" is not lighted, anything else out of the ordinary? Or is the unit non-functional since it senses that the door is not lock and therefore would not engage any cycle?
To read the error codes, pls:
  • plug the washer to the mains;
  • wake the washer by pressing any button;
  • wait for a few seconds to stabilize the electronics/circuitry;
  • press and hold the Start/Pause and Cancel buttons simultaneously.
As long as the buttons are held, the failure code will appear in the display as an E followed by two (2) numbers, a number and a letter or two (2) letters. The control will beep and the Door Lock, Wash, Rinse and Final Spin indicators will flash. Pls note and postback the error code displayed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 09, 2008 | Frigidaire ATF6000ES Front Load Washer
Frond load washer Frigidare ES1
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 you need to replace door lock..
hope it helps
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I press the start button and it says error.
Had the same symptoms. Tried unplugging power for 5 minutes, no change. Did the Select+options button for 5 seconds, the column of lights flashed once, and then I hit the Start, the door locked, clean clothes followed shortly thereafter :)
Jun 12, 2006 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
166 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
