IBM/ by Lexmark Won't function
Tag on lid says IBM/ by Lexmark Wheelwriter;1000 This is not the newer 1000. Approx. 10 yrs old. When I turn on the power the carrage or nothing moves. 2 green lights flash next to line space key [ 1 & 2 ] and the machine beeps a cople of times. I took the case off and reset all the connectors on the board, motors, etc., but did not fix problem.
Any Ideas?
Thank you
  • 3,594 Answers
The keyboard is probably bad. They are available from us for 100.00 exchange.
DickO
bizmach@earthlink.net
Posted on May 03, 2008
WHEN I TURN ON THE IBM LEXMARK ALL LIGHTS GO OUT AND KEYBOARD DOESNT WORK
Your probable problem is either the power supply or function board. The fact that the lights go out usually means it is not a keyboard problem. Does the machine beep and if so, how many times?
Jun 02, 2015 | IBM Lexmark 6781-024 Wheelwriter 1000...
Wheelwriter 1000 tape does not lower
There should be a little gear beneath the carriage you can turn, which will lower it:
http://cincinnatiprinterrepair.com/ibm-typewriter-ribbon-too-high
Jan 14, 2014 | Lexmark Wheelwriter 1000 Typewriter
Ibm wheelwriter 1000 1 & 2 lights come on and
It sounds like a bad keyboard, you can try my tip under WW1000 or contact Geo. Beyers Co. for a keyboard rebuild @ 800-392-8085 tell them O'Reilly sent you.
DickyO
May 19, 2010 | Lexmark Wheelwriter 1000 Typewriter
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
How do I use the RePrint or Memory Function?
You didn't give the model of the WW, if it only has a reprint it is not suitable for this application as it will only retype what has just been typed. You will need a WW with a fully addressable memory (store, play and delete keys)
DickyO
Aug 10, 2009 | Lexmark Wheelwriter 1000 Typewriter
IBM WheelWriter 10 Series II not functioning.
Could be many things. Take off the case and look for parer clips, staples or other debris on or under the PC board or in the power supply.
DickyO
Mar 05, 2009 | Lexmark Wheelwriter 10 Series II...
IBM Wheelwriter 1000 by Lexmark
Make sure the Lang feature is off. Use the code key witrh the lang key to turn off. also take all caps feature off.. Lawrence
May 07, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000 (IBM) beeping
You may have the R. margin there. Space all the way to the right, press R MAR key. You also could have spellcheck on code 1 will turn it off
Jan 28, 2008 | Lexmark Wheelwriter 1000 Typewriter
Character spacing
Joany, look for a function,usually on the left side of the keyboard on the IBM,that has the markings 10,12 and 15. And if my memory is correct,there will be a series of lamps which light up at the selected pitch. I would look for a key marked "pitch" and press that. Good luck.
Nov 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
165 people viewed this question
k24674
jasbo
jasbo
