50"plasma i have additional problem now switched power off on unit- tried to switch on again- blue light stay's on for a few seconds- standby light flashes once and tv power goes off- will not switch on and stay on cheers alfred
  • 1 more comment
  • radig Apr 30, 2008
    no i haven't got the sound back because i cannot turn the tv on to try your sugestion
    i tried last night to switch the tv on could'nt do it tried again this morning still wont switch on
    thanks for your advice will try it and let you know tomorrow cheers alfred
The best $9.99 i ever spend- thank you very much-i got the sound back following your instructions -the tv on switch started working again after i pulled the plug out for 8hr's-why does this happen? will it happen again if i switch it off at the tv?or would it be better to leave it on standby i'm not game to touch it again now that it is working-thank you again i allready had visions of spending 100dreds of dollars to get it fixed plus to find someone who can do it
Posted on Apr 30, 2008
  • 3,037 Answers
So you got the audio working correct? Sounds like it may be going into a protection mode of some sort now. I would try leaving it unplugged overnight and try again the next day and see if it starts working
  • Benjamin Patri
    Benjamin Patri Apr 30, 2008
    well, your problem right now could be a few things, the tv will probably need to be opened up to check it out but first I would try turning it on about 10 times in a row and if not I want you to unplug it for 8 hrs and then try it, not just having it off but unplugged. If you already did this then it will need to be opened by someone who is experienced with large electrical equipment
  • Benjamin Patri
    Benjamin Patri May 01, 2008
    With leaving it unplugged, it gives the tv what is called a Hard Reset, which gives it enough time to totally discharge itself and reset itself which a simple unplugging and plugging back in won't do, I'm glad that you were able to get it working, have a great day and good luck with the future use of this tv.
    It should work normally and the first thing to always try is the hard reset if the problem comes up again, but if it continues then you might be looking into replacing a part. thanks again
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I have just re-installed my pdp5071 after it being in storage for a few years.. the unit will not power up . at plug-in several clicks at upper left rear of unit ( click - stand by red light on-off, pause...
There are two power buttons on this TV. One on the lower left front and one on the right side. make sure they are both on. During storage it may have deactivated both of them.
Apr 18, 2011 | Pioneer PDP-5071HD 50 in. Plasma HDTV
WHEN ON STANDBY WHEN TRY TO SWITCH ON BLUE LIGHT COMES ON BUT AFTER A FEW SECONDS FLASHES HAVE TO ATTEMPT MANY TIMES TO SWITCH ON ALSO SOMETIMES WHEN TRY TO TURN VOLUME UP OR CHANGE CHANNEL SWITCHES OFF TO...
Hello, Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 02, 2010 | Pioneer PDP-427XD 42 in. Plasma Television
50" Plasma turns off and back on without picture; audio stays on
Yes, you are correct. there are a few component issues on the power circuit board that will need to be replaced. the mani component will be the capacitors and transistors.if not repaired soon, this unit will completely stop working.
Mar 11, 2009 | Mitsubishi PD-5030 50 in. HDTV Plasma...
Start button not working standby light staying
The switch is for 'REC' 'Standby' and "PLAY".
If you leave it switched to "Play" and pull the plug and push it in to the wall receptacle (mains) it should start playing after a few seconds delay. The same for "REC". You use a timer unit on the power cord for those.
If you have the switch in the middle position and plugged-in, you should have a tiny Red LED illuminated. Push "Power" and it should start-up and be ready to use in a matter of a few seconds.
Feb 22, 2009 | Sony MDS-JE520 Mini Disc Player
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
