Question about Linksys Wireless-G WRT54G Router
Need to know how to wire from desk top for lap top, I have router #wrt54g
Http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3988&lid=7553637401B09
HI
Use this link to get the required information
thank you.
Posted on Apr 30, 2008
Will setting up a wireless laptop on Linksys WRT54g router mess with 3 computer ethernet wired connections ? I want to set my lap top to WPA2. Right now it's at WEP:(
it all depends on the win version you have.
Please go here (http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G) and hopefully it will have the answer you are looking for.
Obviously you know how to set up your router, since you already have three computers hooked up.
I have many wireless/wired pc's and wireless/wired mac's on the same router, with no problem at all.
Many routers can handle upwards of 30-40 connections without a problem and high quality ones can handle 254 (that's the max for a class C subnet).
Good luck
Dec 14, 2010 | Linksys Wireless-G WRT54G Router
My desk top will work with the router but the lap top which is wireless will not connect. the message I get is failure to establish a successful connection which my be due to poor signal strength or an...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
Have 2 lap tops,1 desk top. Desk top and 1 lap
For the 2nd laptop, first upgrade the LAN card driver, then reinstall the driver if the problem is not resolved with the driver upgrade.
Hope this helps.
Aug 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Do not know my password for wrt54g want to use Ibook
the default login for linksys is user name: (leave blank) ,password: admin; if that doesn't solve your problem unplug all the cords and hold the reset button on the back of the unit for 30 seconds then gradually reintroduce it to your network.
Jan 13, 2009 | Linksys Wireless-G WRT54G Router
Linksys router vs. hp computer
First of all u should ensure that DHCP server is configured for your required number of computers. this problem seems that you have less clients configured in your DHCP server, existing in router configuration.
Dec 28, 2008 | Linksys Wireless-G WRT54G Router
I need a pass pahase
you can check the the passphrase on the setup page of the your router. does you laptop connects to the router via an ethernet cable.
reply to this post so I can give the steps on how to check it.
Jun 05, 2008 | Linksys Wireless-G WRT54G Router
Setting up router having problems
You don't need to have a WiFi adapter for the desktop. It can be connected using a LAN cable from the PC's Ethernet port to one of the routers Ethernet port. AS long as the desktop is set to "Auto obtain IP add" then it should work straight out.
If the LinkSys WRT54G did not came with a setup CD/Wizard, then you would need to reset it since I can only assume that it has been tried/used elsewhere before and the settings/configuration may not match your ISP and/or your network configuration. Reset involves pressing a small recessed button at the rear of the unit for about 10 seconds or more.
Once the reset was done and your router can connect to your ISP and therefore your desktop to the Internet, the laptop would also follow suit as long as the network settings is likewise set to Auto obtain.....
To verify if you can connect to the router, on your desktop, open a browser and log on to your router using 192.168.1.1,
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 04, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
118 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
