Question about Dishwashers
I have a free standing Danby dishwasher. It is about one and one half years old.. The spray arm does not rotate or spray any water.
    Genius:
  • 3,422 Answers
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Goodluck,
Please don't forget to rate or accept the solution
Posted on May 11, 2008
  • Dishwashers Master
  • 13,433 Answers
Hello
There is a fault in the device - motor, theres noting we can do by text
You need a tech to inspect the washer and repair it.
Good luck, and sorry.
  • 796 Answers
Check whether the supply is passed over to the motor....
and also the motor
    Genius:
  • 1,447 Answers
Whats the exact model?
Posted on Apr 30, 2008
Arm wont spin..drains fine..arm spins by hand fine
If the arms are not rotating then there is not water going through them.
Remove the arms and check all the holes for blockages.
Oct 07, 2010 | Danby 22 in. DDW396 Free-standing...
Dishwasher-bottom arm not spraying
The spray arms can usually be removed by unscrewing (clockwise or counter clockwise depending on brand and model), or squeezing a retainer to release the arm. Before removing the spray arm, place the spray arms (all) in a specific position and activate the dishwasher for a few seconds with wash action. Then examine the position of the spray arms to determine if there was movement from the spray arms. If not, then the spray arm(s) are probably clogged and restricting water flow (which makes them turn). Make certain that you are positioning the plates, glasses, etc. in the dishwasher so that they have access to the water. If still no luck, contact an appliance service company.
Feb 20, 2010 | Jade RJDW2470A Free-standing Dishwasher
Danby DDW399W dishwasher - drainage and spin arm problems
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Nov 19, 2008 | Danby 22 in. DDW396 Free-standing...
Upper basket spray arm
Have you checked that the cover for the water inlet at the top where it connects to the spray arm is attached? It could have worked loose. Just re-attach and your spray arm should "miraculously" start rotating again!!
Aug 21, 2008 | AEG 24 in. Favorit 40630 Free-Standing...
Dnby dishwasher slow...
hmmm..empty it entirely...check for any obstructions, and then, you'll need to have a service professional look into it..sounds like it's motor for arm
Mar 15, 2008 | Danby DDW496W Free-Standing Dishwasher
No water or rotation to upper rack
if its not letting in enough water then this can happen.check water connections or a motor fault.
Jan 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Danby Countertop Dishwasher Spray Arm not turning
now ya need to find out how the food got by the screen and into the pump motor to get shot into the spray arm
Dec 29, 2007 | Danby 22 in. DDW396 Free-standing...
Danby DDW396 Spray Arm
The spray arm is controlled by the force of the water. There is no motor running the spray arm. If water is not getting to the spray arm, then it won't spin. It may be plugged with detergent etc. Just a note re. detergent. You shouldn't use hard or caked detergents.
Dec 03, 2007 | Danby 22 in. DDW396 Free-standing...
Danby 22in dishwasher isnt getting enough water
There are a few things to check. 1. Do you have enough water pressure in your lines? It may not be filling enough. 2.Is the washer balanced? Try making sure that its on a level surface. 3. Make sure that your hose isnt kinked, and check the back in the screen to make sure it isnt clogged. 4. Is it above the height of its supply? If so, try finding a lower space to put it on. 5. Take a cup or two of vinegar and run it through a cycle. 6. make sure that, in the arm, there is no clogs or food. I'm not 100% sure what the problem is, other then its not pumping water into it at first and sounds like its blocked some where down the line. If you've never cleaned it with vinegar before, I'd imagine that would be the problem. Hope this helps
Sep 20, 2007 | Danby 22 in. DDW396 Free-standing...
Spray arm not working
I have to remove my spray arm and put boiling water down the hole and tghen it works
Nov 14, 2006 | Danby 22 in. DDW396 Free-standing...
Dishwashers Logo
550 people viewed this question
Top Dishwashers Experts
