Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Dishwsher gets stuck on first setting does not go through cycle
  • 25 Answers
Does it fill with water? If not it will not go through the cycle. The problem in this case could be a faulty solenoid fill valve or the pressure level switch. You would need to test the voltage at the fill valve, no power here would indicate that the level switch is not activating the solenoid valve. You can also test the pressure switch by removing and gently blowing in through the pipe connection. You should hear a clicking sound as you blow GENTLY(small voulume) in once it has clicked stopping blowing should be followed by another click. Repeat a few times. The valve sometimes sticks and this can free it enough to determine if the solenoid fill valve is broken. It does mean howvever that a new fill valve is imminent as they seldom remain unstuck for long. The switch is located on the right hand side of the washer at the bottom. It has a clear plastic pipe and 3 electrical connections attached (orange black grey). Unplug from mains and remove side panel ( 4 screws on back, 2 inside door seal) The switch is located at the bottom left as you look. Disconnect pipes and gently lift switch up and pull out. After testing return to washer and see what happens. It should at least fill if the switch has been clicking,( it should have clicked when you stopped blowing) if not you probably need a new solenoid valve. Rear left of washer. I performed the above when my washer stuck and found that the pressure switch was sticking. Replaced it £30.00 and it worked. If it does fill with water, but doesn't run then the pump isn't starting and that too can be caused by the pressure switch. Bridging the orange and black terminals on the switch should get the pump to start. Use a short piece of wire with 2 spade connectors to bypass the switch. Start washer once it has filled the pump should now start. If not get a new switch. If it does none of the above then the control panel may be gone.
** Remember never work inside the washer with it plugged into the mains. Fully disconnect before removing any covers and handling wires. If in doubt get a suitably qualified person to do the job.**
Posted on May 08, 2008
  • oysterman May 08, 2008
    Solution 2 always good
Fixed under warranty
Posted on Apr 30, 2008
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
My dishwsher will not drain always tried a bit of CLR then it would drain for a little bit.
Hello..
If the machine has an drain pump..remove it and check the impeller..can be broken if is a plastic made.
If the machine does not have a drain pump...the drain solenoid is bloked on close and the water is not draining.
You can check also the drain hose to see if is stoked somewhere.
Good luck
Jul 02, 2013 | Dishwashers
Problem with heating element?
HI Put the dishwsher in the dry cycle and after a mineute or so feel the element if its hot its ok. If not you need a electrical meter to check it
Feb 27, 2010 | GE Dishwashers
1. My dishwsher has filled with brown stains over
Several methods for cleaning the brown stains. Assuming they are rust stains you need to run a cycle without any dishes and a cleaner. Suggested cleaners are lemon juice or Iron Out. Some people use vinegar.
Racks should be available at your local appliance parts store or online. Appliance Parts at http://www.appliance-parts-warehouse.com and some at sears.com. Most are not difficult to install. Some require some thought to figure out how to get the old ones out.
Feb 02, 2010 | Dishwashers
Motor groaning on GE Triton XL Dishwsher
motor coils partly burned turns different direction in spin
Aug 08, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge quietpower 3 wont turn on
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or Control Board
Replace if defective (note: uncommon problem).
Aug 05, 2009 | General Electric Adora GHDA670N Built-in...
Woke this mornig to find the Bosch dishwaser had tripped the electrics and now will not power on. It was almost through the cycle. There is water still in the bottom though.
The main problem when a dishwsher trips your power is the element has failed. Basically you will need to replace the element and problem solved.
Hope this helps!?
Jun 26, 2009 | Dishwashers
Tablets not dissolving
Sounds like whatever soap you are using is just too much soap your dishwsher can handle. The soap "packs" are usulally an overload of soap for most dishwashers. Just a few teaspoons of regular name brand soap sometimes will cure lots of dishwsher ills!!!
Apr 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
No water coming into dishwaser.
  1. Valve shut off to dishwasher
  2. Float stuck (bottom right front corner inside - check for obstructions)
  3. Kinked water supply line
Greg
Jan 02, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
238 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
