Question about Garmin nuvi 350 GPS Receiver
Garmin NUVi 350
The power button liiks like it has failed, is there a fix for this? Or Should I send it back to the factory for repair. It is only 1 month old.
thanks
  • Garmin Master
  • 2,130 Answers
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and the repairs I make prevent this from happening again.
If its under warranty, call Garmin and send it back. No need to worry about this if its under warranty.
If not, and you would like for me to reasonably repair your GPS, please email me at KS3R at sharc dot net.
- Jim
Posted on Jul 22, 2008
  • SHARCNET-USA
    SHARCNET-USA Aug 09, 2008
    Note to all Garmin Nuvi 350 Users with a Defective On/Off Switch:
    1. In order to repair this problem, you need to have surface mount desoldering/soldering skills as well as the appropriate soldering tools and case dissassembly tools. Without these things, you take the risk of further damaging your Nuvi, possibly making it impossible to repair.
    2. Resoldering the switch is not going to resolve the issue long-term. In some cases, the switch can not be resoldered and additional rework must be performed.
    3. In order to fix this problem once and for all, the switch needs to be mechanically secured better to the main PCB using pre-tinned buswire. In addition, a custom-fit piece of plastic needs to be glued behind the switch to give it additional support.
    FAILURE TO DO THE ABOVE WILL RESULT IN THE ON/OFF SWITCH BREAKING AGAIN.... GUARANTEED!
    For a reasonable price, I will repair youf Nuvi on/off switch and put in the modications so it doesn't happen again. Repair takes 1 day, units are sent back the next day. Please contact me at KS3R at sharc dot net if interested. I have references.
    - Jim
    Problem Solver:
  • 11 Answers
Contact sales@mgaimports.co.uk
Tell Mel that Al sent you.
Posted on Jul 20, 2008
    Scholar:
  • 174 Answers
Why do you say failed, is it wobbly, or do you mean it doesn't switch on if you tap it?
Usually you have to press it and hold it for a couple of seconds before the device spring to life.
Doesn't it switch on at all? Is the battery fully charged?
Posted on Jun 12, 2008
Garmin Nuvi 350 can't see maps after update
Did you contact Garmin tech support? They are pretty good at it.
Mar 30, 2017 | Garmin Nuvi 350 Car GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
No satellite reception on garmin nuvi 350, garmin offer to repair i believe it may be the antenna as i did all the reboots do think if repaired the problem will persist
There is a possiblility that the antenna is defective. Sometimes a factory reboot helps or re-burn of the firmware. One way to confirm an antenna problem is to go into the tools menu and select "about". If the screen says "GPS S/W = 0.0 (should be a real number like 2.9 or 3.0) then this indicates that your antenna is not communicating with the main board.
- Jim
Sep 22, 2008 | Garmin GPS
Nuvi 350 power button doesn't work
buy a tom tom everyone is having trouble with garmin and its not just poert buttons tom tom is much more reliable
Aug 14, 2008 | Garmin nuvi 350 GPS Receiver
My Nuvi 350 screen broke how can i fix it?
Replace screen. Lookup the ebay seller Nuvi2007.
Or send it back to Garmin for repair.
Apr 24, 2008 | Garmin nuvi 350 GPS Receiver
I dropped my garmin nuvi and the power button is jammed in...am i hopeless?
Try to use a dental tool (small hook-pick) to pull it back out, otherwise send it back for repair.
Jan 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
Audio problems
Steps:
1. Make sure battery is charged. Go to Step #2.
2. Press reset button and try it again. If still bad, go to step #3.
3. Try using headphones.
By using the headphones, you are bypassing the internal speakers, which might have failed. If the sound is still missing, the mostly like problem is a defective audio output stage on the motherboard.
Since this unit uses surface mount technology it will have to be sent back to the manufacturer for repair.
If the sound works with the headphones, the speakers have failed. I have seen several postings of speakers failing in the Nuvi 350.
In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Jan 14, 2008 | Garmin nuvi 350 GPS Receiver
Won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Dec 07, 2007 | Garmin nuvi 350 GPS Receiver
Power button don't work
Likely a mechanical failure of the power switch. I called Garmin, described the problem, got an RMA number, mailed in my 350, and received a refurbished unit in less than 1 week.
Jul 09, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
27 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
