Question about LG DLE2514 Electric Dryer
Clothes not dry when the dryer time is up or says it is dry
I have the same type of problem, clothes are not dry when time is up. I always have to add extra minutes. Or play with the controls, pick speed dry but change the level of heat and time.I had someone out and they cleaned the sensors, No Change. I do not use dryer sheets.
  • Karma Dharma Apr 30, 2008
    Thank you for the suggestion. I am paranoid about dryer fires, so it is very clean! I can reach it outside and use my vacuum to clean down at the bottom of "vent". Any other suggestions are welcome.
    Genius:
  • 1,073 Answers
Has any one checked the vent for an obstruction or kink?
Posted on Apr 30, 2008
Takes turning on the drying cycle several times in order for the clothes to be dry.Is there a “best” setting to use?
A clothes dryer is as simple as heat and airflow just like a hair dryer. If you have heat then you are probably lacking airflow. Check that the vent is not crushed or pinched behind the dryer and also make sure the main line is not full of lint or anything else that could be blocking airflow. If this is beyond your skill, strength, or aggravation level then you can call a dryer vent cleaning company. Timed dry cycle is the old reliable setting and clothes should be dry between 30 and 50 minutes. The "best" cycle on a dryer is one that utilizes a moisture sensor bar and thermister to determine drying time without over drying the clothes. This will be found on cycles other than timed dry if your dryer has that feature. Always pay attention to the care labels on your clothing as they will tell you how to care for your clothing such as "tumble dry low temperature".
Feb 21, 2018 | Dryers
My Maytag Bravo dryer adds extra minutes to cycles. If I set it for normal or bulky it will run for some time and when I check to see if it's done it still has over an hour left on it, more than the...
Your dryer has a moisture sensor, if it senses that the clothes aren't dry enough it will extend the cycle. A couple easy things to check:
1. Be sure the spin cycle on your washing machine is working properly. If the clothes are too wet when you add them to the dryer your dryer will need to add more time to get the clothes dry
2. Be sure your lint filter is cleaned after each load, and have your dryer exhaust vent cleaned- it could be clogged.
Oct 29, 2013 | Maytag Dryers
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Taking a long to time to dry doesn.t get very hot
Igreat answer above now here is a great video shows how it works and what to check
Jan 04, 2011 | Dryers
My maytag gas dryer has always taken a very long time to dry clothes....usually 2 hours. I have had it for 8 years and it has been this way the whole time. is this normal?
i would check air flow out of vent normally with plugged vent extreame amount of moisture is present in dryer on high temperature of air moving through dryer is
max about 140 degrees normally with room temperature arpund 70 the drying time is normally 60minutes or less
contributing factors to long dry time
pinched vent hose final rinse cold water
below 50 degrees remove vent screen inside dryer clean with hot water shine flashlight into vent opening verify not plugged if have candy or probe type
temperature gauge verify temperature
at vent exit
Dec 12, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer twists and knots up clothes
Many times, many types of Dryer have a variety of paddles. There are so many different ones, without your model, it's hard to know which your has, however, I have known many people that have had these problems.
  1. knots clothing;
    Solution: I have heard and seen a couple tennis balls or even a soft pair of tennis shoes used in the dryer whilst drying clothes keep this from happening. (again, the paddles make all the difference) I myself have always had Maytag, but even they are not what they used to be, however, the shoe trick works when we dry our large blankets and comforters.
  2. Length of drying time;
    Solution: Gosh, there could be many issues, but the first, I would think you either have too small exhaust tube, or it is kinked, smashed or the wrong type. Even the smallest of kink or flattening on many exhaust tubes will greatly effect the output of the exhaust. The only other thing could be overall length of exhaust, and possible clogging in the tube. Have a idea for a fix there as well. (if this is the rpoblem.
If you would like further discussions or ideas, please post here, and be sure to add as much info on dryer as you can, including year purchased and model number.
If the drying time has anything to do with my immediate thoughts (had similar problem when I just moved and reinstalled my own Maytag) I have a great fix to keep it from happening.
Whirlpool has been a good name for some years, in fact, they own Maytag now, so I am sure we can solve your issue as long as it isn't a problem with your particular unit itself as they do make a lemon evey now and again.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
LG DLE2514 Electric Dryer Logo
107 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
