Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WS-65611 HDTV
I was watching the set and saw some yellow, blue filckers cross the screen. The set does dark. Now does not power up at all. No lights showing, tried to reset but nothing. when I turn on a green light comes on for 2 seconds and powers off.
  • glow worm May 12, 2008
    had the same problem it was the lamp bulb cost around $250 i found service center to do the bulb a labor for around $250 where ever you bought the tv they should finnd you a service center or look on the back of your owners manual 1-800-553-7278
  • 98 Answers
Labor for a lamp should not exceed $80-120 for a reputable servicer (plus mileage). You can install the lamp yourself, and you can purvhase the entire lamp assy, oem, for about $200 online.
Posted on May 15, 2008
My LG 32LN530B works fine but no picture or screen
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Jan 11, 2017 | LG 32" 530B Series LED HDTV - 32LN530B
Polaroid 40" HDTV model tla-04011c
There is no such setting in the device.
Jan 11, 2017 | Polaroid Televison & Video
When im watching my fire tv stick it keeps flashing onto a blue screen then flashing back to what im watching how do i fix this
It just does this with the fire stick, regular TV is ok? If that is the case the fire stick is most likely defective.
Jan 10, 2017 | Amazon Fire TV Stick
I have a pyle pldn72bt and it was working but one day it just went blue the screen stays on blue i could move the mode settings but nothing will show
Check and replace its tuner. It is at its main digital board. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 10, 2017 | Pyle Televison & Video
My lg plasma tv is cutting off the edges of the shows we are watching. I cant find a setting that will take care of it. Can you help
hmm normally these settings are found in the picture settings of the set top box or just a setting in the tv's picture settings now there might be an option to say fill screen that may work best for some or leave the tv in 16:9 some broadcasts may only be in 4:3 at times this is normal broadcasting and not much can be done unless the setting on the picture option is set to fill screen
Jan 08, 2017 | LG Televison & Video
Have a dark band horizontally across vizio tv. Appears to be a backlight, but not sure how to fix
Could be a bad CCFL lamp, if the set usess CCFL back-light system. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 08, 2017 | Vizio Televison & Video
LG 26LH2000 television. Last 2 days when I turned my TV on there was only sound, and black screen.
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 16, 2016 | LG 26LH2000 26 in. HDTV LED TV
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
