Question about Panasonic KX-TS4300B Phone
Static on my phones
What can I do to get the static off of my phone when I use the intercom? My DSL line is seperate so I shouldn't be getting interference.
    Scholar:
  • 68 Answers
Is the "static" actually the DSL on the other line? If the separate lines are run close together, some crosstalk can be experienced. Try fitting a DSL filter to your 'phone, if this stops it, that is the problem. What you do from there is up to you, but if a simple filter fixes the problem, why worry?
If the "static" is still there when a filter is used, it obviously is something else. Try a different 'phone on the line, 1 'phone only, if there are more than 1 or a computer or fax machine on the line. If it is still present, you may need investigation by your provider.
Posted on Apr 30, 2008
SOURCE:
Intercom / page problem with AT&T phones model 944 and 955
Do you have DSL on this line? Make sure you have filters on the lines going to the phones or take the line coming out of your DSL modem and split it to the phones.
Also, try unplugging your fax, computer modem or credit card machine and test the intercom. Sharing one line for several devices can make the intercom unhappy.
Feb 21, 2010 | AT&T 944 Four Line Intercom Phone
Phone line won't hang up
I would check the DSL filters. Your phone should not interfere with the DSL. Make sure there is a filter on any line going into your phones. If there is a filter replace it and see if that works. Also, check other equipment on the line, fax, computer, credit card machine. They will need filters from the DSL too. Remove these other devices and check the line for the problem then add them back one at a time.
Aug 01, 2009 | AT&T 964 Corded Phone
How do you receive fax on hp officejet 4110
Do you have any Digital Answering Machines in the house?
or is it a dedicated line?
anyway heres the link for the 3 digit error codes document, its a public document that can be found by searching www.hp.com using this Article #: bpu02549 or buu02549
anyway as you can see 388 result/solution is the following...
Problem: Unable to complete the connection.
Solution: *Reattempt the fax reception at a different time when telephone line conditions have improved.
Now this means that one or both fax machines can have a problem. So lets isolate the problem.
Place a regular phone into the wall jack that the OJ 4110, if there is a static sound then its the phone line that is having the problem. if there is no static continue on...*Note if you have a DSL Internet service you NEED a filter for the fax*
What this is most commonly caused by is Bad line conditions which can occur in some different ways.
1) If there has been recently a Thunder Storm the electrostatic discharges interupt phone signals.
2) Recent power line downage
3) Recent Phone line downage
4) The phone company upgrading the lines
But basically something is BLOCKING the faxes from hearing each other. That is why you get this error code.
You can call your phone company to run a line trace. The reason you want to do this is so that you can eliminate the possibly of Static, Yes there are differnt types of it;
1) the normal static that you and me can hear
2) the SuperSonic Static, AKA Static in the Higher Frequency Ranges, where your DSL internet connection is. the Fax will pick up on those Higher frequency ranges, and it will cause problems. So put a DSL Filter on the Fax it wont hurt, and most of the times it helps alot.
Again Make sure ECM is disabled.
other than that, try unplugging all devices on the phone system an try...
i think there is alot fo information, i cant think of anything else...
Hope that helps
Jun 19, 2009 | HP Officejet 4110 All-In-One InkJet...
I have the Uniden DSS7955 + 2 - it it on the same line as my broadband computer line and am getting constant static. When I disconnect the broadband line, the static disappears. I had an older model Uniden...
You will need to get a DSL filter to separate the DSL(broadband) from the talk line. These can be purchased at any store that supports computers.
Apr 16, 2009 | Lands Phones
Avaya partner key system phone... we are experiencing static on only one phone on the system... any ideas as to where to look for the problem
When you get the static on a call. Dial another intercom number. Do you still have the static? Is it only on 1 line, try another....
As stated earlier, flip flop 2 extensions and see if you still have it....
Mar 12, 2009 | Avaya Corded Phone avaparp18d
With broadband connected I can't hear a thing on the phone. We get lots of static, voices are very quiet. I have a phone line splitter on the line.
If you have DSL for your broadband connection, you need a filter on every phone jack. These filters are provided by your DSL provider
Nov 11, 2008 | Computers & Internet
Static on line after DSL installation
I had the same issue - DSL company told me to remove the filters. It worked.
Jan 22, 2008 | GE 25951EE2 Phone
Constant static and interference
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
HUM
DSL line. Possible that filters are not plugged in. When DSL service is being used on your line, filters must be installed at every jack that is in use. The DSL signal can cause static/noise, squealing (similar to fax tones) and other issues on your line. (ex. Caller ID problems). In order to avoid having this issue, the service provider gives DSL filters to all customers when they sign up for service. These microfilters must be used because they allow your phones to work properly by blocking the high frequency DSL signals from being transmitted through the telephones. DSL filters should be plugged into EVERY phone jack that has a phone. If you are not using the filters provided by the telephone company, this will cause static/noise and possibly Caller ID issues on your phones that are plugged into jacks without filters. Please contact your service provider for filter information and proper installation. Interference: Other 2.4 GHz products. Other products that use the 2.4 GHz band can interfere with the use of this phone. Items include: Radio towers, pager towers, cell phones, other 2.4GHz cordless phones and 2.4 GHz intercoms or monitors. If any of these items are in the area, they can interfere with the performance of this phone; try relocating the phone. Other 5.8 GHz products. Other products that use the 5.8 GHz band such as home networking (wireless modems) other 5.8 GHz cordless products (phones etc.) can interfere with the use of this phone. Try relocating the phone. Interference from microwave. Microwaves work on the same frequencies as the 2.4 GHz phones. If the unit is on when the microwave is running, it is normal to experience static at that time. Do not plug this phone in the same outlet or near the microwave. Environmental. Normal radio operation. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. Try channing channels. Surge protector or modem. Unplug modem or surge protector that is connected to the unit. Building structure limits range. Relocate telephone base near window when using telephone outside. Base unit located in basement or other low area. Relocate telephone base to higher location. The unit will get better reception if it is not located in a low area. Video displays, television sets and personal computers may cause interference. Video displays, television sets and personal computers can cause interference on this phone. Please relocate the phone to an AC outlet were there is no major appliance plugged in. If the base is near any of the above mentioned, locate the base to another room. Possible telephone line/service problem. Try using your equipment at a different location (i.e. friend or neighbors). If the unit functions properly in the new location, contact your local telephone company for assistance; additional charges to be incurred by customer may apply.
Feb 11, 2006 | Vtech VT 9152 Cordless Phone (VT-9152)
Panasonic KX-TS4300B Phone Logo
102 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
