Question about LG LFC20740ST Stainless Steel
How to remove/install door handles
We dented the door handles and we recieved new ones and can't figure out how to remove them. Can anyone help us with this?
    Genius:
  • 1,073 Answers
Are these not held inplace with allen screws
Posted on Apr 30, 2008
    President:
  • LG Master
  • 2,651 Answers
They "simply" lift off and the new ones will "snap" back into position.. sarcastically say simply, but that is in fact howe they come off you will need to lift the m up and with some considerable force i might add.and grab with 2 hand s and lift!!!!!!!
Does any one know how to remove the extended cab chevy 2010 rear door panel
remove the screw from the bottom of the handle then twist the handle off . next remove the small square cover that was behind the handle . there will be a screw , which you need to remove . remove any other screws in the panel and it should pop off .
Feb 14, 2014 | Vehicle Parts & Accessories
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
I have a Kenmore Refrigerator/freezer, model # 59673503201. The freezer door was dented, so I ordered a new one, which arrived without a handle. I removed the 8 screws on the inside panel and attempted...
The handle is held by screws and butter clip. You removed the screws,but also release the clips.If in case the clips break during removal,then you can replace the clips too.The cost of each clip is $2.There are two clips in total.One clip on each side of the handle.Once you release this clips the handle should freely come out.To see how the clips look.See the fig below:-- helpmech_57.jpg
This clips are called butter clips or mounting clips.To order this clips if required.Please click on the link below:---- http://www.repairclinic.com/PartDetail/Mounting-Clip/1023807 -------------- If you want door handle removing diagram for your refrigerator: Click on the link below:--- see the diagram:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00001.png ---------------- If you require new handle then click this link directly:---The cost of new handle is $21.----- http://www.repairclinic.com/PartDetail/Handle/1070320 ------------ Also for more help,if you require,freezer door disassembly diagram.Please click on the link below:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00004.png ---------------- This should help.Thanks.Helpmech.
Jan 26, 2011 | Refrigerators
Install door latch cable
Technical Instructions
See picture below
1. Remove door trim panel and water shield per
NOTE: Place a strip of masking tape along the edge of door before removing trim panel to prevent scratching the door with the trim panel removal tool.
2. Snap cable housing end from slot on inside door handle assembly and disconnect cable.
NOTE: Use care to prevent bending of cable housing retainer bracket.
3. Remove rear window channel retaining bolt to allow access to door latch.
4. Position a block (screwdriver handle) between the latch and the door inner panel and snap the cable housing end out of slot (towards inner panel) on door latch assembly and disconnect cable at latch.
NOTE: Use care when removing cable housing to avoid bending of the latch. Discard cable.
5. Hook up new cable at latch and snap cable housing end into slot.
NOTE: Make sure the cable housing is fully seated in the slot.
6. Apply a light film of Teflon grease to the barrel end of the cable. See Figure A.
7. Install return spring. See Figure A.
NOTE: Ensure that the push button rod is located between the spring and the door inner panel.
8. Install foam block at latch. See Figure A.
9. Position water shield over the return spring and install push pin to retain upper portion of water shield. See Figure B.
NOTE: Push pin goes in the same hole as the return spring.
10. Clean hands of grease before performing step 11.
11. Remove protective backing along the lower edges only of the water shield. See Figure A.
12. Install latch water shield at door latch. Pinch the exposed adhesive surfaces together to secure the water shield. Check to insure water shield is not showing through the door shut-face latch access hole. See Figure B.
13. Attach cable to inside door handle assembly and snap cable housing into slot.
NOTE: Make sure the cable housing is fully seated.
14. Check the gap as shown in remote control using a 3/16 drill bit shank end. The drill bit shank should fit in the gap without any clearance and a tight fit is preferred. See Figure C.
15. If the drill bit is too loose or does not fit, adjust by bending the cable bracket as required.
16. Place plastic wedge on remote bracket as shown. Wedge must fit with at least a light press fit for retention. See Figure D.
17. After installation, Apply a dab of special Teflon grease, supplied with the service cable to cable housing openings at inside handle end. The grease should surround and contact the cable all the way around, to seal the opening between the cable and the cable housing.
18. Check all latch functions to insure correct assembly of latch system. If the inside handle does not release properly, replace the inside handle remote release mechanism.
19. Reposition and install trim panel using new push pins if required.
Dec 07, 2010 | 1993 Ford F250
Broken exterior door handle. Can't figure out how to remove old one and install new one.Seems like it ought to be easy.
Well, it is easy, kind of...
It gets released from the inside of the door. there are cables or rods attached to it that need to be released.
May 22, 2010 | 1992 GMC Jimmy
I have a dent in my rear passenger door driver's side and I want to take off the inside door panel I was wondering if anyone has had to take one off and what is the best way to do it thanks
I have removed several of these. First remove all visible screws, including arm rest, window crank/buttons and lock handles. Then with large flat-tipped screwdriver, gently pry all the way around the door panel until it is all loose. Then gently pull the panel up and off.
Jan 22, 2010 | 2002 Toyota Camry
I HAVE A DENT IN THE REAR PASSENGER DOOR AND i WANT TO TAKE THE INTERIOR PANEL OFF AND TRY TO POUND IT OUT. I DON'T WANT TO SPEND THE MONEY ON BUYING A MANUAL. THOUGHT THAT IF I COULD TAKE THE INTERIOR...
Door panels are one of those things that when you suffer through doing it the first time, you find that it really is an incredibly easy job. The trick is finding out how to do it the first time. . Door panels are held be snap connectors. You would do well in going to the parts place and buying a door panel remover tool. Without this tool, you will invariably ruin the pressboard material around a few of the snaps. A large screwdriver will do, but still, it is an iffy proposition. . Find all the screws in the handle (often behind plugs) pop the snaps with the tool, hold the panel away from the door metal some, and yoink it in an upward direction. It will life UP. Careful with any wiring. Electric windows will need to be disconnected first. (Remove the control panel by often prying up. Careful.) Manual windows will need the handle removed - often done by sliding the snap loop off of it. It is located between the handle and the door panel itself. . An alternative way - if the dent is an "oil can dent" is to use the big suction cups that some body shops have. If the dent is creased in any way, you'll need to remove the panel. Good luck.
Nov 25, 2009 | 2001 Cadillac DeVille
Need to open door panel
there are a series of screws around the bottom of the door panel and some in the center in the handle or under it and you will have to pull the door panel off it will seem stuck but if u get a corner off you can see the push pops which are flanged plastic that hold the panel on tightly all around if they break you can buy new ones at most auto parts stores
May 19, 2009 | 2003 Ford ZX2
Back door panel removal
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
Oct 18, 2008 | 2006 Toyota Sienna
Broken handle
you can call the danby company at 800-263-2629. i get parts there for mine all the time.
Jul 29, 2008 | Danby DWM5500 Front Load Washer
LG LFC20740ST Stainless Steel Logo
106 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
