Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Acer will not run 640x480 screen res
Hi i bought a new cd rom (kids game) i have a lcd acer al1715, the game requires the game to be run at 640x480 - the monitor doesnt go this low - is there ANY WAY i can play this game as i get 'data not supported ' floating around my screen - pls helpppppp b 4 i go mad
  • auprincess Apr 30, 2008
    Hey scotty, wld be good if i could get a lower refresh rate but can only go up ....75 is my next option from 60...but thanks and if u have any other brainwaves - be sure to let me know :)
  • 186 Answers
It probably will support. It most likely gives this message because the refresh rate is too high when it switches to that resolution. An LCD monitor runs best at 60Hz. I'm currently on a mac so I can't recall clearly the PC steps, but I believe you can right click on the desktop to get a menu. Click on Properties. Then click on the settings tab. In there you will see an advance button. Then a new window will open with more tabs. In there I think the refresh rate is in there maybe in the monitor tab. This will although, probably only change the resolution you're on. But if you have an extended driver support for your model, you may also have a list somewhere of the Refresh Rate Hz for different resolutions with out having to change the res in order to change the Hz rate. ALSO - in game settings or menu options somewhere of the game, there might be a Refresh Hz Rate somewhere. Confusing enough?? :-)  I know you'll figure it out, I only hope this helps a bit. - Scotty
Posted on Apr 30, 2008
  • Scott
    Scott Apr 30, 2008
    60Hz is what it should be set at for all Resolutions of an LCD. My feeling is that when the game switches to 640x480 res. it changes to a higher Refresh Rate (Hz) at that mode. It would up the Hz in order to minimize flicker at lower resolution for a CRT monitor, but LCD monitors don't naturally flicker due to the nature of the liquid crystal - normally a good thing. Keep me posted - Scotty,
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Is there an installation CD with this monitor? I'm giving it to a friend, but don't remember what all came in the box when I bought it 3 years ago.
Well, these monitors do not require any sort of installation software. hence, you need not worry about the CD. The box would have probably included the monitor, its stand, power cord.
Rate it, if it helps.
Aug 03, 2009 | Acer AL1715 17" LCD Monitor
Changing Screem Res to 1024x720
Hi LSmitten,
So your brother has laptop, and you can't change the screen resolution, I will take a guess that most likely the screen resolution right now is 800x600 or 640x480 which most games won't work with. The most likely culprit why you are not able to adjust the video resolution is that he hasn't installed the video driver of the laptop yet. You should install the video card driver for your laptop in other for you to change the resolution of your desktop. I suggest that you download the latest video driver from the computer manufacturer's website.
Also if he is using a older laptop, the LCD screen on a laptop has a set maximum resolution that you can use only. Older model laptops can only go as high as 800x600 upto 1024x768. Most of the new laptop nowadays have a minimum LCD panel of 1280x800 widescreen. Check the PC manual to see the max resolution the LCD can handle.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
AL1715 Acer this really is annoying
It's seems your monitor went into hybernation... Hehehe... Just kidding! :) Actually, you got a burnt out backlight inverter. It's time for a replacement. Good lucks, have a nice day!
Sep 19, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
OSD popping up
well most osd problems are occuring due to corruption of the rom chip that holds the data you can flash the data back but... not my fav thin gto do.
a nre video board will be your best course.
Jun 09, 2008 | Acer AL1715 17" LCD Monitor
Acer AL1715 17 in. Flat Panel LCD
call the service center instead of wasting time
Aug 28, 2007 | Acer AL1715 17" LCD Monitor
Acer AL1715s
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :(
Apr 20, 2007 | Acer AL1715s (Silver) 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Sep 02, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
