My tascam 2488 does not transfer wave files properly to my pc.after recording and saving the song when i transfer the wave files via usb not all of the tracks come across to my laptop pc. is there an issue with the fat 16 not reading the files correctly ?
  • 19,396 Answers
Check cable first
Posted on Apr 30, 2008
  • Ginko
    Ginko Apr 30, 2008
    Check usb cable first, defective cable can stop files
    downloading .
    You can also try reinstalling software. disconnect tascam from usb when reinstalling software.
    It can also be a problem with tascam memory (not because is fat16, the software handle fat16 as well as 32), in this case you can solve it re formatting memory from Tascam menu.
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
How do i import the tracks from a cd to the track board?
i tried everything to import my rap beat into my tascam 2488 neo it wont let me says that i want a anotrher cd
how do i know which cd to put the wave file in cuz all i did were convert the beat into wave file in itunes and burn it as data on the cd and it wont do it i also burn it as music on the cd it wont do it what do i do?
Jul 25, 2009 | Tascam 2488 Portastudio Multitrack...
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
Transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
Feb 07, 2009 | Tascam 2488 Portastudio Multitrack...
I can't import midi files
There shouldn't be any compatibility problems, especially since you can transfer files one way already. You might want to make sure any wav files you are trying to import to tracks on the 2488 are saved as 'mono' waves rather than 'stereo'. The 2488 won't import a stereo wav file.
Another problem sould be naming. Try to stick to the old dos 8.3 naming standard (xxxxxxxx.xxx) for any files which you wish to import.
Hope this helps.
bd.
Dec 24, 2008 | Tascam 2488 Portastudio Multitrack...
Can't import song from PC to DP-02 Unit and the Manual STINKS!!!!!
You shouldn't have to do any formatting. If you copied a wav file onto the DP-02 while connected with the USB and with the USB connection open, then you were already accessing the fat partition. One thing to be aware of is that the DP-02 only works with mono wav files. So if the wav file from you PC is being saved as a stereo wav (which is the default for most programs) then you'll have to specify mono instead. The DP-02 only works in 16 bit as well so on your PC you should be saving and wav files you wish to import as 16 bit, 44.lkHz mono wav files). That should be about it.
Hope this helps.
bd.
Sep 30, 2008 | Tascam 2488 Portastudio Multitrack...
2488 as an interface
yes if usb connection
yes if you can connect line in line out connection
yes pararlell port connecting
May 07, 2008 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
Usb file transfer
In reading and working with the unit, I have learned that the file transfer is for backup only. If you want to manipulate the file they have to be transferred individually via your sound card or an interface.
Jun 21, 2007 | Tascam 2488 Portastudio Multitrack...
63 people viewed this question
 Grubhead
Grubhead
