Question about Toshiba Satellite A105-S4074 Notebook
Dual Core When I enable the dual core option from the F2 system menu and reboot my laptop, the system crashes during the Windows XP loading screen. when I disable the dual core function it boots just fine, but I receive a terrible frame rate when playing any games or watching any video.
  • Lkoftan Apr 30, 2008
    I'm running XP Media Edition. I was having trouble with my laptop for a few weeks and finally broke down and ran my system restore. I had given it to a friend of mine who actually did the restore, and i believe did a full hard drive wipe before the restore, so I'm not sure if he had disabled the core before or after. If I enable the core, then run my system restore, would that fix the problem? I don't have any Windows XP Media Edition cd's, only my system restore disks.
  • Scott
    Scott May 11, 2010
    XP Home or Pro? XP Home doesn't support it, but if XP Pro then we'll keep digging on issue.
  • 558 Answers
If the dual core was shut down when xp loaded (installed) it would crash when trying to run two cores.
Posted on Apr 30, 2008
  • Scott Hill
    Scott Hill Apr 30, 2008
    system restore should do it you just need to run the dual core when your are loading the new image
Laptop doesnt boot when multi core processing is enabled
By multi core I assume you mean when enabling all of the true processor cores. In your laptop's case it's a Dual Core processor which means there are only 2 phyiscal cores and does not contain HyperThreading Technology (HT Technology) which enables "Virtual processor cores"
Could be caused by a couple of things:
1. Your processor doesn't support multi-core processing which is a possibility given there is no HT technology for your CPU. In which case there is nothing to fix. Even though the BIOS may have this option. You can check to see if both cores are enabled when you have multi-core processing disabled; In windows right click on your taskbar and click on "Task Manager" Click on the performance tab. You will want to count the number of processor displays you see. Refer to this to see what I mean:
The reason I have 8 CPU displays is because I'm running an i7-3820 CPU which supports HT Technology; So I have 4 physical processors cores and 4 virtual processors cores (created by HT Technology architecture)
2. You are running Core2Duo CPU with dual physical processors and have disabled 1 of the 2 cores because your laptop won't boot. This sounds more like you need to update the BIOS on the motherboard or maybe a bad CPU might be the cause as well.
Hope this helps.
Sep 12, 2013 | Toshiba Satellite M505-S4945 PC Notebook
When starting it appears normall gives F2 and f12 option after that the screen becomes black
Was the laptop on? Projector on?
If so this = No.
Toshiba Satellite C600 specifications,
http://egadgetsclub.com/laptops/toshiba-satellite-c600-notebook-review-specifications/
Intel Pentium Dual Core T4500,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#NetBurst_based_Pentiums_2
Go to F2 option. That should be - enter BIOS Setup.
Look at the main menu (Which it automatically goes to)
Or use Down Arrow to highlight Standard BIOS options, and press Enter key.
Is the Harddrive listed? HDD0 has harddrive info listed to the right?
(HarDDrive0)
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | Computers & Internet
Dell Inspiron 1545 red processor:Pentium(R) Dual-core CPU T4400 @2.20GHz is error code 2000-0221, how to solve this problem?
this is a bios level error, you should still be able to run the system. this code is something you get when you hit F12 and run the diagnostics? or is this a blue screen error? you are probably going to need to boot to F2 (setup) then hit "Alt e" Alt F then Alt B the system will beep on the alt f but that's ok once this is done hit esc, save changes and reboot and see if you still get the error
Feb 10, 2013 | Dell Red 15.6" Inspiron 1545 Laptop PC...
My laptop is acer aspire 5542G, it is struck on bios shows the following : phoenix secure core(tm) NB copyright 1985-2008 pheonix technologies ltd. all rights reserved v1.05 cpu0=AMD turion(tm)...
Hi
you could try to press F8 on startup eg press power key then press F8 holding down for a few seconds and hopefully it will take you into some repair options
i would try the last known good configuration option to start with
then windows will restart and try to repair it back to when it was good
and if that dont work try the safe mode/system restore
hope you get it sorted
many thanks
Mar 15, 2011 | Computers & Internet
I get my sony vaio vgn-nr120e blue screen after windows xp laoded
Use the F2 key on startup to enter BIOS. on second page change the dual processor to single and then save and exit. Until you find out the fix, don't re-enable the dual processor or it will mess up the system and you will lose files and it' will show the blue screen of
May 30, 2010 | Sony VAIO VGN-NR120E/S Notebook
Cannot connect to the internet
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. GO TO EXIT AND SAVE.
Mar 29, 2009 | Compaq Presario F730US Notebook
Require Audio Driver for Lenovo 3000 N200 type 769 dual-core
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP audio driver for your model laptop,
www-307.ibm.com/pc/support/site.wss/MIGR-39956.html
Feb 22, 2009 | Lenovo 3000 N200 Notebook
Toshiba problem
On boot go into your BIOS and set your CD/DVD ROM drive to first in the boot order options, then with the CD/DVD in the drive reboot your computer and wait for a prompt to "Press any key to boot to this CD" and do so (you'll only have a couple of seconds so be ready or reboot again) and you then will be taken through the loading of files until you get to your partition/install screen options, where you'll delete the partition that your OS is on, then create a new one and then format that partition and install XP on it.
May 07, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S4074 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
