Question about HP PL4260N 42 in. Plasma HDTV
PL4260N Getting Pulsating Lines Across TV Screen. Checked connections and cable OK
  • eamaral May 31, 2008
    Amazing, same thing happend to my PL4260N on the same date.
    I was watching a show and hundreds of vertical white lines started crossing the screen. No solution so far..
  • derstewie Aug 31, 2008
    I have the same problem - it goes away and comes back...but is getting more frequent. I thought it was the connection and replaced all the cords, but even when I whitewash the screen it does the same thing. Oh well I guess it's time for a new TV.
  • 4 Answers
I also have 2 horizonatl lines that roll about a foot apart up the screen...
i have been told twice now by two different people that it is a cable grounding problem, so if you have cable tv call the company and tell them what it is doing, i was informed they are aware of this problem and can install a filter at the main cable in line and this should solve this problem...which since i just had this looked at this morning i am going to be calling the cable company today!
hope this helps
Posted on Dec 09, 2008
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
After replacing y-sustain board have nothing but vertical lines on screen
well..sounds like the main control board to me..these things tend to fail as a group, by the way...
Oct 16, 2008 | HP PL4260N 42 in. Plasma HDTV
Shadowy horizontal lines on plasma tv
Would have helped if you posted the make/model of the TV as well.
Apr 09, 2016 | Televison & Video
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
I have a Grainy Screen with Horizontal lines, There is picture behind this. Is this th Ysus Board? I have a HP PL4260N 42 In
Is it only when connected to the computer? If so there are several settings that could be causing the issue. The biggest is the refresh rate, make sure it's set to a max of 60HZ. Also make sure the resolution is not set to high. If your TV is 720p it's 1280x720, for 1080p it's 1920x1080 MAX! Also make sure the cable is tight on both ends. If all this is okay, it may be a hardware issue, but it's doubtful. Try hooking the computer to another TV.
If it's not a computer the issue is most likely either the source resolution or the cable.
Good luck
Apr 10, 2014 | HP PL4260N 42 in. Plasma HDTV
Green vertical lines across the screen.
Green lines on LCD screens generally means physical damage. Did you drop it or bump it by chance? Physical could also include the cable that you are using. Try using a different cable, or make sure it is connected all the way.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 05, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Little lines across the screen about 6 lines going from Side to Side. What can be done
look it up online.. some guy uses a baseball bat to fix that on his lcd tv.
its a LCD panel connection issue, not really much other than hitting/ flexing it you can do.
Aug 07, 2009 | HP PL4260N 42 in. Plasma HDTV
Tv on no picture no sound tv making a pulsating humming noise.
Hi phalbeis, Unfortunately it looks like the power supply has failed, since the unit is new I would check into the return policy of the store you bought it from, if your lucky you can just exchange it. If not it will have to be shipped back to the manufacturer.which can be a hassle, you may have to pay the shipping to the repair facility.
Let me know how it goes and please rate this solution. Lone99star
Jan 21, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
Getting Pulsating lines across screen
I have 2 horizontal lines that roll up my screen about a foot apart
i have had 2 different tv repair men tell me it is a CABLE GROUNDING problem
you should call the cable company (if you have regular cable) and supposedly they are aware of this type of problem and can install a filter at the main cable in box and hopefully this will work for you
Apr 29, 2008 | HP PL4260N 42 in. Plasma HDTV
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
HP PL4260N 42 in. Plasma HDTV Logo
71 people viewed this question
Top HP Televison & Video Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
