Question about Refrigerators
Gas fridge for boat
Its switched for lpg. The burner wont stay on. The flame failure device has been changed and is working there is a spark . when i try it with the combustion chamber open or off it will light ok .its a sealed chamber about the size of a large match box with a air in take and air exaust out letits as if there is to much gas or air . i have tryed everthing to control the air encluding reducing pre airnation (thats spelt wrong) and my gas presure at the valve is 31 mil bar not that much above 28
  • 1 more comment
  • tyronegas Apr 30, 2008
    yes every thing you say is correct , but i dont have a flame, it wont light for me there is gas .air , and spark... it may light one time in two hundred trys and the flame looks pefect, blue with a slight orange tip and stays lite. yes flame falure device , thermocouple safety device same thing help help
    yes tried that as well ,had the spark making contact with the burner and and then making contact with the thermocouple witch is higher up still no good ??help
  • Sunspot24 Jun 22, 2008
    Similar problem. If ref not used for several days, it won't light up on gas, on initial trials- many of them.
    But-- if the ref has been operating on A.C. for over an hour, and I switch to gas, it will light up OK and be Ok until the next time it sits idle for a few days. Then it won't light up again.
    It will never "gas" up when cold started.
    Andy
    Sunspot24@tampabay.rr.com
  • 828 Answers
What you are referring to as the flame failure device and there is a spark? On gas refrigerators there is generally a thermocouple safety device. This thermocouple shuts off the gas if it does not receive heat from the flame to generate the millivolt current to hold the gas safety valve open. If this thermocouple is bad it will allow the flame to be lit but it will go out as soon as you manually release the depressor that opens the valve. Your supply pressure is in range. If you have to much primary air you will get a flame lift of from the burner. To little primary air and you will have a dirty and lazy flame.
Posted on Apr 30, 2008
  • James Helmer
    James Helmer Apr 30, 2008
    Check the position of the spark at the flame head ( Burner) and have someone make it spark while you are watching it. Spark may not be making in the gas stream.
The stove is on a 2004 boat - I assume the stove is original. The burners light, but it just took me ages to boil a cup of water in a sauce pan with the lid on. Do old stoves lose their efficiency?
Gas stoves don't usually loose heating efficiency. Check that the gas control is allowing it to go from low to high. Being LPG, there may be a pressure problem. LPG have a regulator on or close to the bottle. Being on a boat, I would get a competent / licensed Gas Tech to check it. Better to be safe. LPG appliances on a boat can be very dangerous if not serviced or repaired properly.
Sep 17, 2015 | Force 10 Two Burner Built In Propane...
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
I have a rinnai LPG 6 burner gas heater, it starts fine but wont ignite the middle left burner. It has a blue flame over the top that occasionally radiates down the burner. All the other 5 burners work...
sounds like the injector hole is too largefor that burner have you had it converted reciently
lpg injectors are only half the size hole of natural gas injector, could have a blockage in the injector diverting the gas flow
Jun 09, 2011 | Rinnai Heating & Cooling
Imperial ifs 40: gas comes out of jet and the burners work fine for a moment, then the flame ignites inside the burner and makes a worbling noise every now and then popping. is this low gas...
Check your manual and make sure your burner is configured for the gas that you are using. In most cases, there is an orifice that needs to be changed for using LP, or a screw setting that needs to be changed- most new appliances ship with a "city gas" configuration ( AKA NG - Natural Gas) and need to be configured for LPG (Liquified Propane Gas). The fitting(s) that need to be changed are tagged. This is due to the pressure difference between NG and LPG. Propane (LPG) runs at a higher pressure.
You state that your fryer is LPG. If you are running it on NG ("city gas") you need to consult your manual for converting it to NG. Outside of making sure that you are set up for the right gas, you should not have to make any other adjustments. For safety reasons, gas regulator pressure adjustments are for the most part no longer possible on gas appliances.
Mar 21, 2011 | Imperial IFS40 Deep Fryer
Burner will not stay lit. Push in knob-- flame starts, but will not stay lit as soon as you take pressure off of the knob, no matter how long you hold the knob in. Also, on other burners, I cannot reduce...
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
Jan 15, 2011 | La Cornue Grand Palais 180 Dual Fuel...
Natural gas to LPG conversion kit for old new world gas stove
Silver solder up all burner jets and redrill to .6 mm then reset adjusters so you get a nice blue flame with small orange tips.and oven burner to .8mm i have just done a new world 75 last week.Works perfect
Apr 14, 2009 | Ovens
M2800 fridge
If it doesn't click or the light doesn't flicker it is probably either you don't have good strong 12 volt power getting to the fridge(12 volt required only to light on gas the first time) or else the little gas igniter module went out looks like this only sometimes black.
Now if it won't stay lit. It is something wrong with either your flame or your thermocouple. First try just blowing out the the flu right where the flame comes out blow compressed air in so if there is dirt or cobweb in there it comes out the back side. If that doesn't help disconnect your thermocouple and wipe the end and then connect it back up and tighten it. If it still wont stay lit still replace the thermocouple.
Sep 15, 2008 | Dometic RM2652 Refrigerator
Gas fridge
Check the point at which the spark makes contact with the burner head. You may have to reposition the spark igniter, be careful not to brake it.
Apr 30, 2008 | Refrigerators
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
