Gas valve main wont open - Heating & Cooling
    Problem Solver:
  • 10 Answers
Does the pilot valve open? Does the pilot flame impinge properly on the flame sensor? A low or weak/yellow flame will not activate the sensor adequately to bring on the main valve. Call your gas supplier to have this looked at and follow their recommendations.
Posted on May 03, 2008
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Old anthes gas furnace with pilot light. burners will not light.blows cold air
Have to think that the thermocouple has failed if the pilot is on but the furnace main burner doesn't ignite
Apr 05, 2014 | Cozy (W352E) Heater
Wont heat
do you hear 3 clicks when you start it up,these clicks are the gas valves opening to supply the unit with gas for operation,if no clicks are heard it can be the thermal fuse is open,if only 1 or 2 clicks check continuity of the main and secondary gas valve coils as they can open up or get weak from heat during operation,usually just replace both coils on the gas valve as they are inexpensive one has 3 connections and the other has only 2 connections,but first bypass the thermal fuse with a jumper wire (for testing only) then replace the gas valve coils next,unplug both coil connections then remove 2 screws holding the valves to the valve and replace and reverse dis-assembly procedure
Feb 07, 2012 | Kenmore Dryers
Gas thermostat control not opening
if you mean the gas wont turn on after trying to light it could also be a bad thermocouple , it can't feel the heat so it wont open the main gas valve , this is a cheep fix
Sep 12, 2010 | Blodgett 1060 SINGLE Gas Pizza Deck Oven...
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hi the pilot light is on but the burners wont kick on
the main valve might not be opening check for power to main valva if you have power and still dont light you most likely need a gas valve. also make sure you have a good thermo couple
Jul 06, 2009 | Heating & Cooling
Pilot staying lit but the burners will not ignite
The cheapest place to start is with the thermocouple or thermopile, if it is not sending the right millivolts signal to the main gas valve then it wont open & allow gas to the burners. The next would be the t-stat and then the gas valve.
Jun 25, 2009 | Kitchen Appliances - Others
Kitchen and bathroom faucets do not get hot,hot.Lukewarm at best.
ok the way it works man is the box aka power vent the gas valve wont open until the power vent is open u can manualy open the powervent witch will open the gas valve to turn on the piolt light and in about 30 sec the main burner will kick on now if the powervent is opening the the pilot light isnt lighting then u need to replace the thurmole cuple witch sences the pilot light is on if it doesnt see the pilot the it shuts the gas valve off so it doesnt fill ur house with gas
Dec 28, 2008 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Dryer gas valve
the valve should be closed until the coils on the top are energized and opoen the valve check the incomming connection for leaks all gas valve fail safe that is to say they wont fail to the open position.. use some dish soap and water on the piping into the unit and around the valve to find the leak
Mar 15, 2008 | Dryers
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
