Jvc iart AV-36DF74 problem
Juice going in...."on" light blue as usual.....nothing.....black screen, no sound. About 7 years old.....very light usage.
    Novelist:
    Scholar:
  • 148 Answers
Age and usage are tricky to determine the life of a set. Chemicals in the electrolytic caps can still age and degrade even tho there is no use.
Your best bet would be to check with a local repair house to see if they have any experience resetting the set as it may have simply failed it power on test.
If you are willing to perform some checks yourself, Which I would not advise unless you know what you are doing as the tube can retain lethal voltages for several months after power off. check some simple things that are required for the thing to pass a power on test.
Check the de gausing coil around the set and make sure it gets power when forst powered up, check the de gausing cols thermal resistor and from there check the power supply voltages.
If you have a scope check the signals to the tube itself with a high voltage lead..
if you dont have any of theese tools you may need to take it to a qualified repair center. I do know JVC has a very good repair shop here in chicago. but other large cities may be hit or miss.
Also for now, simply try and leave it unplugged for a while in hopes of resetting the internals.
You may also try and verify your inputs, like with the remote check that the input is set to what you need.
Posted on May 01, 2008
Jvc AV-48WP30 iart pro the color on the screen is falling down on the left side the colors are not overlapping so it doubles what ever im watching
Replace your STK iCs, they are big black ICs will have the Part number on them example STK392-110
Mats has STKs 1-800-628-1118
Jul 02, 2010 | JVC AV-56P575 56" Rear Projection...
I have a jvc iart television and i had to transport to my apartment now i have green and red colors in each corners.. How do i remove those colors??
hello,
the problem is a colour patches , you can solve this by using a big size magnet like that in an audio speaker to remove the colour patches.
you do this when the television is power on, and gently moving the magnet towards the screen of television.
hope this will help...
May 21, 2010 | JVC AV-27F802 27" TV
Blue lines arc down from the top of the screen on JVC IART TV model number AV-65WP74. Is it worth fixing? Thanks
Yes it is worth fixing . You can fix it yourself for about $ 21 . You need to replace the convergence I.C. chips , The part # is STK392-310 . you need two of them . You can get them from bluestar-online.com . They are about 6 bucks a piece and about 10 for shipping .
May 13, 2010 | JVC AV-65WP74 Rear Projection Television
Blue grid lines of color convergence seems to be stuck in a postion: 1 grid box to left. tried to manually set but no luck. (JVC IArt bbe 74")
The AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com should fix that issue the kit contains the parts and the CD with detailed instructions.
Nov 17, 2009 | JVC AV-65WP74 Rear Projection Television
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Convergence problem
sounds like convergence amps bad
Oct 23, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc Av-48wp30
try unplugging for a few seconds the plug it back in
Jul 11, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP30 Two Years Old. Up And Croaked
Hi What you are discribing is a condition call power supply overcurrent shutdown the TV is going into a protection mode to prevent further circuit damage you really to call in a tech with JVC projection TV repair skills to fix this problem for you good luck windman
Oct 25, 2005 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
