Question about Tomtom GO 510 GPS Receiver
Reset button Where is the little rascal ?
  • JC Parks Dec 13, 2008
    where is reset button
  • wgoz Apr 07, 2009
    WHERE IS THE RESET BUTTON ON A TOMTOM GO 510
  • 515 Answers
Trouble shoot Rascal 200 mobility scooter. Horn works. That is all.
Hi check reset circuit reset button .it might have tripped . Cheers
Nov 26, 2016 | Health & Beauty
I have to push joystick back to go forward. An forward to go back. Much faster in reverse too
if you look under the seat and see that there are little black switches, one of them maybe broken. if there are no switches on the seat post. then your joystick thinks you are a front wheel drive instead of a rear wheel drive chair. Someone with a programmer can reverse this. get ahold of these people at this link I give you to find a technician close to you.1-800-257-7955 or Mobility Parts and Service Official Rascal Parts Supplier
or http://www.meritsusa.com/
May 02, 2016 | Rascal 318 Electric Scooter
Does anyone have arepair manual for a rascal 300 I need to fix the electromagnetic brake
It is the same as a Rascal 600 only the 300 has smaller wheels.
The manual is not much help on the brake, it does not go into repairing the bake, except for checking voltages and replacing the microswitch, some tips are a little oil on the detent balls help to keep it free and movable, but don't get oil on the brake pad.
Scooter Doctor App
Aug 27, 2014 | Rascal 300 Electric Scooter - Used...
How to reset a rascal control panal
To reset the control panel turn the key off then back on. If you are receiving a flash code, once the the code has been corrected restarting the with the key will reset the control panel.
Scooter Doctor App
Jun 01, 2014 | Rascal Used Electric Power Wheelchairs -...
Rascal 600T Scooter FIX IT Manual
There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
If you have a good relationship with a local dealer they may be able to copy and provide you with one.
Electric Mobility, the manufacturer, in my experience will not provide one to you.
Mar 02, 2014 | Electric Mobility 3 Wheel Motorized...
HELP ! My Rascal joystick has option to raise & lower height of chair; I raised it to get in my freezer and now it will not lower. When it is in the RAISED position, the speed is less than a ONE a
This device either is hydraulically operated or operates use a motor and jacking screw, which is much more common. Take the seat off the jacking post. Put a piece of wood on the top where the seat was mounted. It should make the same kind of motor noise going down as it makes going up. If it never made noise going down it probably because its a hydraulic system so the down button activates a valve opening a hydraulic line allowing fluid to flow out of the chamber holding the piston up that your chair is mounted on. If it did make the same kind of noise going down, its a screw jack type mechanism. In either case hit the top of the wood once with moderate force. I like using a 5 pound hammer. I call it my master calibration tool. Make sure you strike the top of the wood piece straight down in order to avoid bending things. Try operating it now sometimes things get stuck when moved to their limit. So push the reverse button, then tap the piston down. You can check to see it the motor is getting voltage you will need a 24v circuit tester
http://www.amazon.com/OEM-25886-6-24V-Circuit-Tester/dp/B0014WIVX6
I would like to see pictures of his devise. Any tag or stickers with who made it, model number?
Jul 28, 2012 | Electric Mobility Rascal Scooters,...
2001 rascal electric wheelchair booklet
Call customer service at 1-800-257-7955, the assure me that they will be able to assist you.
Dec 14, 2011 | Electric Mobility 4 Wheel Power Electric...
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Sep 24, 2010 | Golden Technologies Golden CompanioN II -...
Can't have multiple connection
hi,
this product is a modem *** router. so it must be able to give you multiple connections.
this may be due to some firmware problem.
you can try a reset of the D link. press the button behind the unit using a small sharop pointed non metalic object. hold the button for 5 to 10 seconds.
this will reset all the functions of the unit. this must clear your problem.
check this solution and get back to us if you have more problems.
thank you
Sweet rascal.
Aug 25, 2009 | D-Link DES 1005 Ethernet Switch
GPS Logo
144 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
