Question about Sony SDM-HS75P/S 17" LCD Monitor
Blank Screen, Flashing orange power light...
When I plug the monitor in the power light just flashes orange. Pressing the power button has no affect on the light. Nothing appears on the screen at all.
Ideas? I have the soldering iron ready to rock!
  • 1 more comment
  • Oneitchyeye Apr 30, 2008
    Thanks for the quick response Scotty! Checked for obvious burn spots, re-soldered some of the weaker spots thinking it might just have been a cold solder joint. I was trying to figure out what the blinking light might mean. I know the SONY tv's blink as a diagnostic but can't find the info on the LCD. My guess is a power issue too. I might just pop down to the electronics store and swap them all out. I think the board is $95 to replace and this is a 17" monitor so not really worth it but I enjoy the challenge of the repair. Keep the ideas coming :)
  • riaadpal Apr 16, 2009
    I have the same issue with the same monitor. Please help..
  • Anonymous Apr 26, 2009
    same problem - sambasiva rao, Hyderabad India 9848016293
  • 51 Answers
@scottyfixit..i agree with with this guy..but there is also probability for this..if your ram is damaged the screen comes blank flashing tht orange light..try to remove the ram and rub the golden bottom with an eraser and try to reinsert the ram and then go for a try..!!
Posted on Feb 13, 2010
    Scholar:
  • 186 Answers
1st Idea - Let's take a look under the cover. I'm not sure how tech savvy you are, but I'm sure you're pretty good if you have a soldering iron. Once inside locate the power supply section. See if you see any blown capacitors on it or any other boards. One obvious way is to see if they are bad is if they have bulging up tops. There could be some weak or bad ones that aren't popped up, but let's start from there. If there are any bad caps, they are dirt cheap price wise at an electronics shop. Keep me posted and let em know what you find. - Scotty
Posted on Apr 30, 2008
  • Scott
    Scott Apr 30, 2008
    I had a KDS 17" LCD come through the repair shop that could come on and go right back off. Under built power supply blew 6 Caps. $5 later it was alive again.
Gateway blank screen
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 04, 2014 | Gateway Computers & Internet
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Acer Computers & Internet
I have an LC-32D33X sharp tv... it just turned off on me :( and now the OPC and the power lights on the tv are flashing SOS style :(
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
Mar 06, 2012 | Sharp LC Televison & Video
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops. http://en.wikipedia.org/wiki/Capacitor_plague
Common problems fro 2~3 years old monitors/ TV.
Jan 03, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
Reset 19 lx
Try pressing the "Menu" button and look for "Settings", find "Factory Settings" and select.
Sep 13, 2009 | Computers & Internet
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Monitor screen blank and LED orange light flashing
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
Aug 18, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
Sony SDM-HS75P/S 17" LCD Monitor Logo
788 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
