Question about Bosch Kitchen Ranges
While runing the clean cycle on my 2 day old bosch hgs7282uc gas range, it came up beeping error code 120 after an hour or so of it running.
I PURCHACED A BOSCH HGS7282UC GAS RANGE 6 MOS AGO. THE DOOR WONT CLOSE TIGHTLY,THE HEAT ESCAPES AND HAS MENTED MY KNOBS ON THE STOVE
Posted on Sep 26, 2008
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Bosch dryer is beeping and showing error code, E01,after a few minutes of running then shuts off.
Clean the Duct hose mine was doing the same thing and now it will run the full cycle no problems. Also if you are in a high humidity area it may be blocking up with condensation.
Jun 05, 2010 | Bosch Dryers
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Approximately 2 hours into the self-cleaning cycle the range starts to beep, displays error 154, and stops. Does anyone have any suggestions of what is wrong and how to go about fixing it.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 04, 2010 | Bosch HGS5052U Gas Kitchen Range
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code
Try unplugging or turning off the breaker for 30 mins then plug it back in and see if you still have the 160. I'm surprised that it doesn't have an F anywhere in the code. How old is the oven. Could some of the lights on the control be out. they are LED's and sometime they do burn out. I'm thinking this could be an F06 code which could mean anything from a power surge (clock) and needs to be reset (like I said by switching of the breakers or unplugging) to an EOC (Electronic Oven Control) failure. By switching off the oven and waiting about 30 mins. if it doesn't come back on it will be the EOC. make sure the LED (light emitting diodes) aren't out on the control making you
Dec 20, 2007 | Bosch HDI7282 Dual Fuel (Electric and Gas)...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
661 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
