Question about Koss KS2503 System
Every thing works but the sound
It was working now i turn it on and its has a low pitch hum i checked every thing whats going on
  • Anonymous May 13, 2008
    plays movies and sound come out of the tv but no sound from the surround speakers what do i do?
  • dmccormick3 Dec 28, 2008
    Did anyone figure this out? I have the exact same problem as everyone else, it seems.
I have the same problem, dvd works but no sound only a buzz sound.Did I blow something
Posted on Sep 02, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
My samsung dishwasher will not drain? What could be causing this problem. We checked the line and it is not plugged.
when you first start the dishwasher the first thing it will always do is drain, does it make the normal draining sounds or is it a low pitch humming noise? if its a low pitch humming something is stuck in the drain pump like a peice of chicken bone or glass, if it sounds normal then there is a blockage somewhere and 9/10 times its the little drain spiggot that the drain hose plugs onto under your sink, they often block up as the pipe diameter gets smaller there
Oct 08, 2014 | Samsung DMT400RHS Builtin Dishwasher
Low pitched humming
When it makes the noise and you able to do this try turning to the right and to the left. If the noise changes or goes away than your on the right track with a bad wheel bearing.
Dec 27, 2012 | 1998 Pontiac Grand Prix
Was working fine. started burning ac line fuses and noticed a little smoke. I found a bad light switch going to the ac outlet it was plugged into, which I think has caused this whole problem. removed the...
u have a shorted primary power supply unit on your amp. for linear supply check diodes and capacitors. for smps chek switching transistor or any other switching component. if u have no idea get it repaired by a tech.
Jan 30, 2010 | Sunfire Cinema Grand 200 Five 5-Channel...
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Nov 19, 2009 | Samsung HL-S5087W DLP TV
2004 Chrysler Crossfire 25,000 mls auto, road hum noise
MOST of the hums after a while come from the diff as the back axle does the driving and almost all its life runs the same way except when going in reverse ,is the rear diff meshing and worn on both the crownwheel and the pinion and the humming gets slightly louder the faster you go and almost goes when almost stopped and this can also be the slight vibration you get so get the diff oil drained and refilled and check if there is any metal in the oil when drained if so thats your problem But it will last for years like that..Let me know how you get on RON
Oct 23, 2009 | 2004 Chrysler Crossfire
Left front wheel noise, accelerates as if 'winding up' and hums
Have tires checked, but sounds like possible wheel bearing going.
Aug 03, 2009 | 2000 Pontiac Grand Am GT
Alesis m1 mk2 active emits low pitch hum and does not work
You need to take a closer look really, see if anything on the power supply board inside has melted, burned, popped, etc.
Mar 13, 2009 | Alesis M1-Active MkII Main / Stereo...
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Koss KS2503 System Logo
73 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
