Question about Kitchen Ranges
I would like to know how to set up my timer to have my dinner turn on at a delayed time. I'm unable to find it in the manual.
  • cvanmuyen Oct 19, 2008
    can't find my manual.. Would like to know how to ue the delay setting
    Genius:
  • 1,073 Answers
What is the model number
Posted on Apr 29, 2008
Hb51r manual
Plug in
make sure bulbs work
rotate dial to set choice of delay times
timer turns on at dusk,,, and delays off for amount of time you choose
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Gene
Dec 13, 2013 | Intermatic Outdoor Timer/Photo Control...
I need to know what to set my dials/sttings on 1EJE8 Dayton Timer. What I am trying to do is sound an alarm when I hit reset the timer shuts off the alarm for twenty min before resounding
Question is unclear.
Help me break it down.
You want to push a button and sound alarm?
And then you want alarm to sound until you push button again?
And then you want timer to delay 20 minutes before sounding alarm again for an unknown amount of time?
What is the reset?
Add a comment and say what control you have wired to the timer and a clear 1-2-3 sequence of events and times for possible help.
1EJE8 is 10-function timer, and no manual appears on the internet July2011.
Magnecraft has same-similar timer, the 820 series.
Open following link for detailed manual with illustrations.
http://www.serelays.com/library/section5/105A_820_Series.pdf
Jul 14, 2011 | Amperite Dayton Solid State Timer On Delay...
How do I turn off the delay timer? When I set it up, the timer automatically sets it on a 3 hour delay. I have moved the up & down arrows but it won't set at 00:00 unless I unplug it. Then I set...
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Jun 20, 2011 | Breadman TR777C Bread Maker
I can't find the self timer on my fuji finepix av camera
Press cursor-down (marked with a one-handed clock), then choose the desired delay. Start the self-timer by pressing the shutter release button.
Full details are in the "Using the Self-Timer" section of the manual (page 31 in my copy). If you need a manual, you can download one at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/finepix_ax200_manual_01.pdf
Jun 06, 2011 | FUJIFILM FinePix AV100 Digital Camera
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
I have the H5CR-B 100 to 240 V AC digital timer. How do I change the timer from minutes to seconds?
You have a DIN panel mount SPDT (single pole double throw) timer.
This is input ON delay timer that receives input that causes timer to start a delay countdown, or signal off delay timer that receives input that causes timer to turn on for specified countdown, or a cycle timer that repeats same program pattern over and over in a set amount of time like every 5 hours and 12seconds, or an ordinary interval timer.
Apparent manuals:
http://www.servodrive.ru/dynamic/managers/manage_15/files/L035E14B_H5CR_datasheet.pdf
http://www.omron247.com/doc/pdfcatal.nsf/04769EAAF1D7005686256B8100629A62/$FILE/D19H5CR0302.pdf
Manual says: Field-selectable time ranges from 0.001 second to 9999 hours.
My impression is that this means timer can be set for durations ranging from .001 seconds to 9999 using the 1-4 keys
Manual says: Change the timing range with the increment keys (1 to 4).
Use keys 1-4 to change data when setting timer when in the set mode.
It looks like you set seconds or milliseconds with #1 key
Manual shows contact information
Measuring and Supervisory Controls Department
Shiokoji Horikawa, Shimogyo-ku
Kyoto, 600-8530 Japan
Tel: (81)75-344-7108/Fax: (81)75-344-7189
OMRON CANADA, INC.
One East Commerce Drive
Schaumburg, IL
1-800-55-OMRON
http://www.omron.com/oei
885 Milner Avenue
60173 Scarborough, Ontario M1B 5V8
416-286-6465
Feb 02, 2011 | Omron Hardware & Accessories
I have a fan timer that delay for 30mins for every set time but the problem is when the power is out it loses its memory and start with 30mins delay all over again
Power outages are not that common.
If I understand correctly, you have or need some kind of automatic delay timer, like the Paragon ET series.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#ET
Or maybe the Dayton off delay timer.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Or you have an occupancy sensor with time delay like the Tork SSA.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#SSA
Is this timer hard-wired into a box, where it gets steady power?
Is the timer supposed to have a back-up rechargeable battery?
If this is a digital Tork box-type timer, most of those timers have a power-loss carryover.
If you can identify your timer, or say more details about how your timer operates and where timer is located, and what fan Load is, I might be able to suggest an alternative that works for your purpose.
Add a comment.
Dec 14, 2010 | ICP Vortex Fan Timer Control Board For Air...
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
Delay-bake timer not working
I have given you the instructions for the timer for the B2200 and B2250 models. I hope this answers your question. I have also included a link to the manual in case you don't have one.
Carol.
6. Timer Buttons
Press these buttons to set the time for delay bake (up to 13-hour
delay). For example, you can time your bread to be ready for
dinner or when you wake up in the morning. Set it by selecting
how much time you want to pass before the bread is completed.
For example, if it is 8:00 p.m. and you want the bread to be ready
at 7:00 a.m., set it for 11 hours.
You can also use these buttons to adjust the time of the cycle.
They adjust up or down in 10-minute increments. Changes must
be made before the unit begins operation.
http://www.useandcaremanuals.com/pdf/B220,B2250984.pdf
Jan 19, 2009 | Black & Decker Bread Machine
Kitchen Ranges Logo
163 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
