FixYa.com
Tags:
Haier XQG50-11 Front Load All-in-One Washer / Dryer
Washing machine
posted by tavarus on Apr 29, 2008
the water is draining out as it comes in , it keeps coming out of the detergent dispenser and out of the drain spout
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 30, 2008
FixYa! (100)
premm
Rank:Guru Guru
Rating: 93%, 2338 votes
What height is your drain spout? The pipe should be about 3 feet up and then down into the sink or wall standpipe; there should be a water mark behind the machine Your pump pumps the waste water OVER this height. At present your drain pipe must be lying at floor level, which is not correct.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
Haier XQG50-11 Front Load All-in-One Washer /...
trouble shooting
Err7 flashes up when i put spin... Answer This...
Spin cycle problem
The slow spin part of the cycle... Answer This...
HAIER WASHING MACHINE
keeps stopping while its... Answer This...
Need an on/off switch
Where can I get this part? Answer This...
replacement part not available
I checked with Haier on getting... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
