Question about Lavazza Espresso Point Capsule Machine
Lavazza coffee maker does not recognize that it is filled with water
  • Anonymous Feb 24, 2009
    i have the same problem
A small water sensor needs to be replaced, you can pick one up, from sovrano, or a supplier pretty easily,
Posted on Aug 27, 2008
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
I am considering buying a Lavazza LB2210 Espresso Machine. Owner says the screen says "fill with water" after she descaled the machine. What kind of cost am I looking at to get this fixed?
There is a floating plastic block in the water chamber that sits next to a sensor in the machine, that tells the machine whether the water reservoir is full or not. if its stuck, that could be the simplest fix ever. It could also be the sensor at fault, but it should be easy to test the float first
Sep 24, 2010 | Lavazza 2210
Just need instructions to descale my Lavazza Blue coffee machine
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Sep 05, 2010 | Lavazza 2210
We were using tap water to fill the machine for about 2 months...now, nothing comes out at all....do you think it has something to do with hard water?
Probably, unless the heating element has burned out. All coffee makers suffer from the same problem. Use a 50/50 solution of cold water and white vinegar--run it through several times, then run just cold water through until the vinegar taste is gone. Good luck!
Jul 25, 2010 | Lavazza Espresso Point Capsule Machine
Lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Feb 05, 2010 | Lavazza Espresso Point Capsule Machine
Machine is spewing grounds into the cup
This is usually an overfill of grounds or the water distribution nozzle is not distributing the water correctly. First, put no coffee in the unit. Just fill a cup w/hot water. If it still is putting out grounds, the upper basket has coffee grounds stuck in the nozzle. If you get no grounds, try reducing the amount of coffee used.
Nov 09, 2009 | Lavazza 2210
Coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Jan 08, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza espresso point
Did you fill it with water? are any of the lights blinking?
Jan 02, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
211 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
