Question about Garmin StreetPilot C320 (010-00401-00) GPS Receiver
My garmin c320 wont track any satalites
Hi, my garmin c320 has a clear view of the sky but about 90% of the time it says a message " are you indoors" meaning it cant track any satalites i don't know what to do. or if there is anything to do. can some please help me. thanks
  • palleyne May 04, 2008
    it is the same as what has been said. has a clear view of the sky and will not grab any satalites. i have even tried standing outside of the car and will not sync either. help please
This will completely wipe all data on your unit including almanac data (satellite information).
Your unit would then need at least 20 minutes with clear view of the sky to update the almanac and reacquire.
To reset the unit you need to press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold 'power'. You need to hold both for 30 seconds.
Posted on May 26, 2008
Hi, my garmin c320 has a clear view of the sky but it cant track any satalites i don't know what to do. or if there is anything to do. can some please help me. thanks
Posted on May 23, 2008
Rino 530 keeps loosing signal was hunting in Canada using rino while walking . keeps saying no satalite
The GPS needs a clear view of the sky and at least 3 or more satellites to get a fix on your position. If you are under a heavy canopy of tree cover / brush, it can affect accuracy and even the GPS's ability to get a fix at all. Also, if you are in a mountainous region, the geometry of your location and the location of the satellites over the equator could be obstructed, resulting in the lost satellite messages. You must have an unobstructed view of the southern sky to get a fix.
If you are able to get a fix in an open area, the GPS is able to do its job, but the location you're trying to use it in is offers too much interference to capture satellite signals.
Making sure you've got the latest firmware from Garmin can solve a lot of troubles, too. If you still believe that your GPS isn't working the way it should, contact Garmin Support.
I hope this helps - and good luck. Please rate my reply - thank you.
Feb 23, 2011 | Garmin Rino 530 GPS Receiver
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
I used my 705 on my trainer and it did not record distance or speed like my forerunner does. The 705 works fine on the road
the Garmin Edge series rely on GPS to track your location from point A to point B thereby calculating your speed and distance. Its no different from any other GPS unit which require a clear view of the sky. It does not sense wheel movement, so using any GPS on a trainer will show no movement and using it indoors will give you a bad signal. The sensor on the crank used on the Edge 705 is only for cadence and not speed.
Jul 16, 2009 | Garmin Edge 705 Handheld GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
C330
Go outside with a clear view of the sky. You won't be able to get a signal indoors, or even in a parking garage. The unit needs a clear view of the sky.
Dec 24, 2008 | Garmin StreetPilot C330 GPS Receiver
IS THERE ANYTHING SPECIAL I HAVE TO DO WHEN FIRST USING THE GARMIN 350....I TURNED IT ON AND IT WONT PICK UP THE SATELITTE
Hello gdepari,
Take the GPS outside into an area with a clear view of the sky and turn it on. The unit may take up to five minutes to lock onto satellites and determine your current location. The GPS needs to receive data from at least three satellites. If you are operating indoors, in a vehicle, in a city with tall buildings, or in an area with tall hills or mountains, your view of the sky may be blocked. This can prevent the GPS from locking on or can cause it to take additional time getting a satellite lock.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 22, 2008 | GPS
Long wait to pick up satalites
Hello ebadaloni,
In order for your GPS to pick up satellites it needs a clear view of the sky. Obstructions such as tall buildings, trees and local terrain such as mountains and hills can affect your receiver's ability to "see" the sky. This is also true of GPS's used indoors or inside of a vehicle.
A GPS receiver without a clear view of the sky can take a long time to get a fix on its own location. The process can also take additional time if the GPS has been powered off for an extended period of time or if you have traveled a long distance (greater then 500 miles) since it was last turned on.
If the GPS is taking longer then five minutes to achieve a satellite lock when used outdoors in a clear area this could be a sign that the GPS needs service. If you are using the GPS indoors or inside of a vehicle with no external antenna then the GPS could take a long time to acquire a satellite lock or could fail to achieve a lock.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 17, 2008 | GPS
Tracking satalites
Update the firmware from Garmin website, and do master reset. That should fix the problem. worked on mine
May 23, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Garmin StreetPilot C320 (010-00401-00) GPS Receiver Logo
256 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
