Question about Husqvarna Viking 1
The tension is way off and the tension dial doesn't correct the problem
  • 2 more comments
  • Laura Connor May 15, 2008
    The thread from the bobbin (on the bottom of fabric) tangles and sometimes the thread in the bobbin tangles and jams inside the bobbin case.
  • Anonymous May 15, 2008
    the tension on the bottom of the fabric bunchs up when I am quilting using the free-motion foot on the quilting frame
    Breeze
    The thread tension bunch up on the bottom of the fabric when I quilt using the quilting fram
  • roxsew Jun 03, 2008
    The thread tension is off and adjusting the top thread tension does not seem to help. I was machine quilting and it was working fine until I filled a bobbin. After that the tension was bad, thread bunches up on the back. seems that the top thread tension is too loose. HELP!
You need to explain which tension, upper or lower. In other words, does it bunch up on top of the fabric or below it.
Posted on Apr 30, 2008
Cannot adjust tension
Using the thread tension dial on the left side of the machine you can adjust the upper tension.If i; doesn't work properly see if there's a thread that stuck.Buy a brother sewing machine
Sep 22, 2012 | Brother Sewing Machines
Upper tension dial on White sewing machine turns complete circles
try a top tension of 4 or if you have a automatic setting try that
if that doesn't help then the tension dial need to be checked
to see if some thing is wrong with it, it might need to be replaced
Sep 09, 2012 | White Sewing Sewing Machines
I am trying the tention,, and topt is fine,,under neat is loose
try adjusting the top tension
make sure the needle can be used for sewing fleece
try rethreading the machine ,make sure each thread guide is used
if you try changing the top tension & the machine doesn't respond to any tension setting then maybe the tension dial needs to be replaced
make sure the bobbin is inserted correctly in the bobbin case
make sure the bobbin is wound correctly
clean under the needle plate & in bobbin area for lint or loose threads
Apr 01, 2012 | Brother Sewing Machines
My Singer 14u64A ultra lock is nearly impossible to get a decent tension...I have threaded, and reyhreaded... What in the world can I do?
try cleaning the tension dial with unwaxed dental floss, in between the disc's
then try a tension of 3 to 5
if this doesn't work the tension dial may need to be replaced
Mar 28, 2012 | Sewing Machines
How to balance zigzag thread tension in singer 5830C sewing machine
if you try to regulate the tension & it doesn't respond then the tension dial may need to be replaced
Mar 15, 2012 | Singer Sewing Machines
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
Top stitch looks great, under stitch bunches. I have rethreaded, rebobbined, changed tension. same result. :(
Bunching of thread is 99% a top tension problem. Make sure you thread the top thread correctly. Thread the machine with the presser lever up. Test the tension by lowering the presser lever before threading the eye of the needle, by pulling the thread with your left hand and adjusting the tension with your right hand while slowly pulling downwards. There should be no resistance when the tension dial is on zero, and you should be able to feel more resistance when you increase the tension. Ideal tension is between 3 and 5. When your top tension is correct, your machine should operate correctly. If you feel no resistance with the presser foot down and the tension dial on 5, check the tension disks for fluff or broken thread. When you lift the presser foot, the tension disks should open and you would be able to remove any cotton or fluff. Good Luck
Aug 30, 2011 | Singer 4423 Sewing Machine
I have a Viking/Lisa Model. I am having trouble with my tension and I am not sure if it is the top or bottom. My bobbin thread is all of the sudden too loose.
I just bought a Viking Lisa, and also had to adjust the tension. Use the manual to make sure you've threaded the machine correctly and put the bobbin in correctly. (I wasn't getting the bobbin thread the way it needed to be.) Then gradually increase the tension on the dial inside the top cover, checking the bobbin stitches every two inches, ending up on about 4 1/2. If this doesn't take care of the problem completely, gradually increase the side tension dial, and between adjustments on both dials, you should end up where the stitches look good. Also make sure to use cotton thread; mine doesn't like polyester thread. :o)
Aug 20, 2011 | Husqvarna Sewing Machines
Tension dial not correcting tension problems
Look to see if the 'check spring" is still there, and not broken.
If the tesion nob can be truned without any feeling of tension, then maybe the screw that attaches the 'tension housing' to the stem has loosen or broken.
May 10, 2009 | Sewing Machines
Janome 6600 tension
You need to do a tension assembly test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Feb 16, 2009 | Sewing Machines
Sewing Machines Logo
143 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
