Question about HP Compaq Presario V2000 Notebook
Power turns off itself then sometimes won't turn back on for sometime
My Compaq presario is 2 yrs old- it turns itself off completely then often will not turn back on for hours.. I've tried holding the button down to restart but it doesn't hold the connection. Why would it be shuttign itslef down?
Have you tried your power options, you might have it set up wrong
Posted on Apr 29, 2008
HOW DO I UNFREAZE ABLACK DSI
  • 1 Hold down the "Power" button for at least four seconds to turn the DSi off. If the system powers off, hold the Power button to turn the system back on and reset the operating system. The system should no longer be frozen. If the system doesn't power off, go to the next step.
  • 2 Plug the Nintendo DSi to the power outlet using its AC adapter. Allow the system to charge for two to three hours. A battery may be recharged 500 times or less before being depleted. Once charged, hold down the "Power" button to turn on and reset the operating system. The system should unfreeze itself; if not, follow the next step.
  • 3 Remove the battery from the Nintendo DSi. Unplug the AC adapter from the DSi. Loosen the two screws with a Philips screwdriver on the battery cover. Remove the cover, then remove the battery. Put the old battery back in or replace it with a new battery. Removing and resituating an old battery will sometimes jolt the system and allow it to unlock itself. Replace the battery cover and retighten the screws. Then, try to hold down the "Power" button to unfreeze the system.
  • Read more :
    Oct 12, 2014 | Nintendo DSi Black Console
    Compaq presario cq60 the caps lock blink constantly
    You may try this fix. No guaranties though. Remove the battery and unplug power cable. Then hold down the "power" button for about 10 seconds. After that plug it back in and try turning it on. Again, this may NOT work but it has for others.
    Sep 08, 2014 | Compaq Presario CQ60-220US PC Laptop
    My Compaq Presario F500 running Vist Home Basic will no longer boot the operating system after I completed an advise BIOS update from HPs websit. I receive an error code stating that the system is cor
    Hi.
    Try this >>>>
    Power down your Compaq Presario F500 notebook computer. Remove the unit's internal battery from its housing compartment.
    Use a screwdriver to unscrew and remove all of the screws from the bottom panel of your Compaq Presario F500. Use your hands to lift off the bottom panel, revealing the inside of the notebook computer.
    Look for the CMOS/BIOS chip: It will be located in the center of your computer's motherboard, which is itself located in the center of the case.
    Remove the small battery from its housing compartment on the CMOS/BIOS chip. Then, press and hold the "Power" button on the laptop's case for a few seconds. This will completely discharge all electricity from the device.
    Replace the CMOS/BIOS' battery. Place the bottom panel of the notebook computer back on and screw it back into place. Place the Compaq Presario F500's battery back into its housing compartment and press the "Power" button to turn it on. Your CMOS/BIOS will now be completely reset.
    Good luck and please let me know how you get on!!!!
    Regards.
    Jan 29, 2013 | Computers & Internet
    Compaq presario fan stopping
    Take it back to the place of purchase since it is under warranty, otherwise you will damage the processor which the cooling fan protects.
    May 03, 2012 | HP Compaq Presario V2310us Notebook Pc...
    Power problem I closed my Compaq F700 and opened it 10 minutes later and it shut itself down and won't power back up. Battery is good and the power cord light comes on when plugged in. Any help? Thanks...
    Press the power button and if it goes on keep pressing the button until it shuts off. Then try to power it up by tapping the power button once.
    How have you tested the battery? In my Acer laptop I'm on my third one in 2 years and recently got a 9 cell high capacity one that lasts 3.5 to 4 hours when my original lasted only 1 or 2 hours tops.
    Jul 22, 2010 | Compaq Presario 700 470024-192 Notebook
    At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
    Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
    Apr 03, 2010 | Compaq Presario 5000 PC Desktop
    Cant turn monitor back on
    broken power switch... .. the "friend" broke the power switch by pressing too hard or as luck had it the switch is broken..
    recommend leaving the monitor unplugged for 4 hours
    open the case of the monitor up and pull the small circuit board for the "buttons" out and get a replacement board... google the part number exactly as spelled out on the little button board
    Sep 28, 2009 | Computers & Internet
    Compaq Presario SR1000 Won't Turn On
    The power on buttom might be it. Before doing anything else, check and fix the power ON button. I have a tower that gave me the same trouble. The Power On button somehow was out of place. Once I aligned it, the tower worked again. Good guess..! Good luck
    Jun 14, 2009 | Compaq Presario SR1000T (568657) PC...
    Startup problems/compaq presario 8000 series
    Here is what I mean. You don't have to get one here, but here are what they look like.
    http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2779&name=3.5-Enclosure-IDE&Nav=|c:2778|&Sort=0&Recs=10
    Jan 15, 2009 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
    I upgraded the BIOS and now my Presario V4000 keeps shuting Down
    Try a system restore. If that doesn't work download and revert back to the old bios.
    Jun 20, 2008 | HP Compaq Presario V5000Z Notebook
    HP Compaq Presario V2000 Notebook Logo
    63 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
