Question about Dryers
Kenmore Gas Dryer (110 70956990) - cycles but no flame comes on - does not receive voltage to flame sys - only found one open at first sensor to right of fan cage in duct(In-RedWire Out-RedWhtWire with one inch betw terminals) RedWhtOutput line feeds to sensor above flame discharge cover.(have no schm). Had already checked coils, glo-bar, & all other sensors & switches. This line obviously feeds thru to the Flame Thermal Sensor and would interupt the 110vac flowing to flame sys. I do not believe an open here is normal but with no shematic and even less experience I need some help. There are two sensors on this Output Air Duct - one is open & other closed. I would have to pay & wait for a manual - rather get expert advise - faster Dan
  • Danny Yates Apr 30, 2008
    I pulled out hte suspected component and found adequate info on the part to determine for sure it was a thermal fuse.
    Microtemp Kenmore DryerThermal Fuse 3390719
    and it is open
    I will replace it and check for any other damage
    I also got a reply but had checked on that page before and there was more general information about various problems - these could all be helpful but not directly to troubleshooting this particular electrical circuit. Thank you Dan
    I had already discovered the problem because I was finally able to remove the component and research p/n on it. The applianceaid site you suggested does mention that some dryers have a thermal fuse as one of several items to check. I needed to know for sure if this component I was testing was indeed a thermal fuse. I needed a schematic or someone to describe the part or a location to settle it for me.
    This was a good reply and would have greatly aided me in troubleshooting and would have strengthened my exsisting suspicion of an open thermal fuse, especially because of its placement in the wiring trace I had done.
    If there is any reason beside the age that may have caused this fuse to fail. Please let me know from your experience since I wll have to wait to receive the part rather than jump test it. Thank you Dan
  • Dryers Master
  • 19,396 Answers
The termal fuse normally blows for overheating, not for ageing. Replace termal fuse, if the problem comes back have your dryer inspected by a profesional.
Gas dryers can become dangerous appliances if not maintained and tested regularly.
I would recommend having a profesional check up done on dryer, particularly if fuse blows again.
Replace fuse with original part, in no case try to bypass it.
Regards
Posted on Apr 30, 2008
    Genius:
  • 1,226 Answers
Maybe this link can help you,
http://www.applianceaid.com/dryers.html
may this help,
melnavz
Posted on Apr 29, 2008
Kenmore Elite 110.7708/9 Gas Dryer...no heat...ignotor glows red and then shuts down...obviously the gas valve is not opening and the sensor needs to be replaced. I have the top of the dryer up and the...
by removing the drum it will free up a lot more space.
(ps) i know what you mean i busted my knuckles more that once when replacing the flame sensor BUT however since the ignitor does go off it is the coils on the gas valve and not the flame sensor ,if the flame sensor where bad the ignitor would come on and stay on for a real long time because the sensor would not be satisfied that the ignitor was/is on
I base my opinion on 30 years experience as a appliance repair technician and in sympthoms such as yours i would replace the gas vavle coils and totally disregard the flame sensor as to the root of the trouble
Jul 22, 2011 | Kenmore Elite HE4 Electric Dryer
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
Jun 17, 2011 | Kenmore Dryers
I have a model 110.92832100 Kenmore Elite gas dryer that has stopped drying. i found a penny welded onto the Thermal fuse, so I replaced it and while I was in there I replaced the thermostat. When the...
Since you are already this far you have some knowledge of how you dryer works. What is wrong now is the heat sensor that picks up that the pilot is on. The pilot should burn at a steady flame when you turn the dryer on to heat this in turn heats a probe next to the piolit this is a type of heat sensor. When the probe or heat sensor senses heat it tells the gas valve that its okay to turn on. Have a great day and hope this helps.
Aug 19, 2010 | Kenmore Dryers
Flame does not cycle on Gas Dryer
This problem is caused by faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves. It is recommended that if any of the gas valve coils are suspected of fault, that they both (all) be changed at once. Hope this helped and best wishes.
Sep 01, 2009 | Kenmore 63942 Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
Kenmore gas dryer is not giving out heat
Check the fuse and control thermostat on the blower housing. They provide power to the gas assembly.
If all of that is good then check the flame sensor. If the flame sensor is open then no power will get to the then the common wire to the coils and ignitor will be open causing no heat. Read more
Mar 19, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer model 110.76814690 will not heat up
The bottom panel is held on by spring clips. Use a putty knife to access the bottom. The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.8f17134.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils NOTE: The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 21, 2008 | Kenmore 63942 Dryer
Kenmore Gas Dryer - cycles but no flame comes on - does not receive voltage to flame sys - only found one open at first sensor to right of fan cage in duct(In-RedWire Out-RedWhtWire with one inch betw...
Hi Dan,
It sounds like you have your hands full there. It really sounds like a bad ignitor. Most ignitors will read some continuity even though they will not get hot enought for the flame sensor to open the valves. If you are sure the ignitor is good the flame sensor would have to be the problem. Good Luck and I hope this helped. Mca0824@aol.com
Apr 29, 2008 | Dryers
Kenmore Gas (propane) Dryer
theres a black box eithr on the left or right of the tube that the flame comes on it. its a flame sensor. when the sensor is bad the ignitor cant come on
Nov 25, 2007 | Dryers
Dryers Logo
90 people viewed this question
Top Dryers Experts
