Question about Dryers
Kenmore Gas Dryer - cycles but no flame comes on - does not receive voltage to flame sys - only found one open at first sensor to right of fan cage in duct(In-RedWire Out-RedWhtWire with one inch betw terminals) RedWhtOutput line feeds to sensor above flame discharge cover.(have no schm). Had already checked coils, glo-bar, & all other sensors & switches. This line obviously feeds thru to the Flame Thermal Sensor and would interupt the 110vac flowing to flame sys. I do not believe an open here is normal but with no shematic and even less experience I need some help. There are two sensors on this Output Air Duct - one is open & other closed. Dan
  • 172 Answers
Hi Dan,
It sounds like you have your hands full there. It really sounds like a bad ignitor. Most ignitors will read some continuity even though they will not get hot enought for the flame sensor to open the valves. If you are sure the ignitor is good the flame sensor would have to be the problem. Good Luck and I hope this helped. Mca0824@aol.com
Posted on Apr 30, 2008
I am working on a monitor 2400. heater will run normal until it reaches set temp. when it goes to mid burn the flame goes out and code 14.
E14 Flame failure: There are obstacles at circulation air inlet or outlet. Fan cage is clogged with dust. Gas pressure dropped when other gas appliances are turned on. (this may also apply to K1 fueled units if you have another K1 based heater)
Here are the rest of the fault codes I found:
Digital Display Reason of indication Trouble Point
E01 At pre-purge, flame rod is sensing flame when there should be none. Flame sensing circuit, grounded flame rod or pinched wire. E05 After power on, power supply to the microprocessor timing circuit is incorrect. Timer clock circuit bad or power cycles (hertz) to unit above or below acceptable levels.
E06 A starting of operation, the circuit to drive photo triac of solenoid pump is malfunctioning. Solenoid pump control circuit has a malfunction.
E08 Revolutions per minute of combustion blower are malfunctioning. Combustion blower or combustion blower control circuit has a malfunction.
E13 No ignition. Failure of ignitor, solenoid pump or circuit board. Incorrect wiring or flame rod touches to burner parts. Air pressure switch or overheat open.
E15 Power supply voltage too low. Voltage too low or power detector circuit has a malfunction.
E16 Load failure of combustion blower motor Flue pipe is restricting air flow.
http://www.keepuswarm.com/upload/M2400OwnersManual.pdf
http://shdashan.com/english/user%20manual%202200.pdf
Oct 29, 2015 | Heating & Cooling
Whirlpool duet front load gas dryer runs but doesn't get hot. any suggestions?
The most probable thing is going to be the igniter. Remove the lower panel,the one below the one where teh door is mounted to. On the lower right side will be the igniter it looks like thisoldtech2332_80.jpgUse a volt meter and check were it plugs into (not the igniter but were it plugs into) and start the dryer and check for 120 volts into the plug..if 120 volts at that plug the igniter is bad and it needs replacing.
If it does come on when starting the dryer before unpluging igniter to check voltage,watch and see if their is a flame..if their is a flame watch it a few cycles and see if a few flame on flame off cycles see if a couple times after coming on if the igniter comes on and goes off but no flame the gas valve coils will be the problem. Here is what the look likeoldtech2332_81.jpg
if the igniter does come on but not go off followed by a flame the flame sensor is going to be whats needed its pictured hereoldtech2332_82.jpg
If NO voltage to igniter OR it doesnt come on,what i would suspect wrong then is either the motor or control board being the trouble. However these things i covered are the most likely things to go out
GENE
Aug 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a model 110.92832100 Kenmore Elite gas dryer that has stopped drying. i found a penny welded onto the Thermal fuse, so I replaced it and while I was in there I replaced the thermostat. When the...
Since you are already this far you have some knowledge of how you dryer works. What is wrong now is the heat sensor that picks up that the pilot is on. The pilot should burn at a steady flame when you turn the dryer on to heat this in turn heats a probe next to the piolit this is a type of heat sensor. When the probe or heat sensor senses heat it tells the gas valve that its okay to turn on. Have a great day and hope this helps.
Aug 19, 2010 | Kenmore Dryers
Flame does not cycle on Gas Dryer
This problem is caused by faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves. It is recommended that if any of the gas valve coils are suspected of fault, that they both (all) be changed at once. Hope this helped and best wishes.
Sep 01, 2009 | Kenmore 63942 Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
Kenmore gas dryer is not giving out heat
Check the fuse and control thermostat on the blower housing. They provide power to the gas assembly.
If all of that is good then check the flame sensor. If the flame sensor is open then no power will get to the then the common wire to the coils and ignitor will be open causing no heat. Read more
Mar 19, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer model 110.76814690 will not heat up
The bottom panel is held on by spring clips. Use a putty knife to access the bottom. The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.8f17134.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils NOTE: The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 21, 2008 | Kenmore 63942 Dryer
Kenmore Gas (propane) Dryer
theres a black box eithr on the left or right of the tube that the flame comes on it. its a flame sensor. when the sensor is bad the ignitor cant come on
Nov 25, 2007 | Dryers
Dryers Logo
81 people viewed this question
Top Dryers Experts
