Question about Whirlpool Calypso GVW9959K Top Load Washer
WASHER FREEZES UP IN NORMAL MODE
PUT IN NEW MOTOR CIRCUT BOARDS, WORKED GREAT FOR A WEEK NOW IS FROZE UP IN THE NORMAL MODE AND WILL NOT START.
    Genius:
  • 1,028 Answers
Suspect keypad stuck
Posted on May 01, 2008
Hello, I have a whirlpool duet wfw94hexlo washer. got an error code, drain filter assy., cleaned it put it together. when you go to start machine all seems normal. you push start, door locks, light comes...
Great! you have the MCU (motor control unit) need to replace. Removing the rear panel so you are able to see the motor and MCU. Replacement is easy, almost no screw on the board.
Oct 22, 2013 | Whirlpool WFW94HEX Washer
My windshield washer does not work
HOOK TEST LIGHT TO WASHER PUMP MOTOR ELECTRICAL CONNECTOR FIRST DISCONNECT ELECTRICAL AT WASHER PUMP MOTOR.NEED A HELP TO WORK WIPER WASHER SWITCH.IF TEST LIGHT LIGHT UP WIPER WASHER MOTOR FAULTY.IF TEST LIGHT DONT WORK.YOU HAVE FAULTY WIPER WASHER SWITCH OR FAULT IN THE WASHER WIPER POWER MODULE IF WIPER MOTOR NOT WORKING YOU HAVE A BLOWED 30 AMP FUSE OR BAD WIPER MOTOR RELAY.
May 22, 2011 | 2006 Dodge Grand Caravan
My front loader washing machine will not spin or start a load. I turn it on and it wants to start but nothing happens. I put a blanket in the washing machine last night and it was very heavy and the cycle...
In the back of your washer their should be a
diagnostic
manual behind the top cover. this manual will show you how to test the motor.
if the motor does not work. your motor control board is faulty. if you look closly at the board , you will see a burnt componet, that means you will need a upgraded board and unfortunely you will need in new motor to go with it.
it cost me around $230. has been working for 2 years with no other problems.
I found the parts on line. if you need help to find it , let me know, and when i get back home next week i will send it to you.
Good luck.
Jun 29, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Refrigerator keeps freezing up. Replaced defraust heater still froze up in about 4 weeks. Tried to replace main board WR55X10037 WITH WR55X10656 BUT THE NEW BOARD DOES NOT KICK MY COMPRESSOR ON. GE SIDE BY...
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore Elite HE5t Washer Error Code F11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Jan 03, 2009 | Washing Machines
Goodman gmp075-3 led blinks 5 times
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Oct 22, 2008 | Goodman GMS90703BXA Heater
WILL NOT AGITATE
circut board mounted on timer assy is the problem, tip the console on its back to verify and put in agitate mode, will work in lay back position, then will not work in normal position. unplug board two times and should start working, it gets scrambled just like a computer, because its a computer. must be a relay on the board, this is what happened to me, and is still working 10 loads later, sounded like a motor.
Jul 01, 2008 | Washing Machines
Kenmore calypso model 11022086100
Thermal overload protector is mounted on the motor. Normally the motor is replaced.
Jan 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
New Player freezes up on or after track 12
this is the same response to another post
the unit i purchased ran great for about 2 months then the video started to freeze. power cycled solved the problem initially, but when power cycling did not cure the problem, i started shaking and tapping the unit. at a point of throwing the unit away - took the cover off to see what's inside. with the cover off, it ran just fine . put the cover back, ran ok for a while then started freezing video again.
twisting the unit appears to make it function..
my solution that appears to work for my unit. .
loosen only the two back screws holding the plastic drive mechanism down to the bottom plate (chassis) assumption is that the metal chassis was twisting the drive mechanism and offsetting the photo pickup.
this has worked for the past 2 weeks without a problem.
Dec 26, 2007 | Toshiba SD-5000
Electrolux Icon Freezing up and no longer cooling
You have a definate defrost problem if the evaporator keeps freezing up. Since your refrigerator is under the manufacturs warrenty you need to make it there problem and get them to send someone that knows what there doing to resolve your problem. there is a timer a terminator and a heater he would need to check out. Good Luck
Jul 13, 2007 | Electrolux E23CS75DSS Stainless Steel
Whirlpool Calypso GVW9959K Top Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal De
