Question about Intel Motherboard
Problem with my motherboard
Hi,its quite a long time am having a big problem,my problem is that I hve a pentium II socket 7 motherboard,its running smoothly but it don't recognize me 128Mb SD Ram. I the even try both PC100 an PC133 memory band but in vain,please help me?????????
I can not find the seristor for the motherboard because the mother board did not open. I put the power cord and i turned on but the fan over the CPU does not working and there is no reponse from the mother board. I change the power supply . it gives the same. so i asked someone he told me there is an seristor in the mother board maybe damadge but i cann't find it can you help me >>>> my mother board is Gigabyte (Model 8S661FXMP-RZ ) Pls Help !!!!!!!!!!
Posted on Apr 30, 2008
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
What is the price of mother board?
Good day..!! I can help to solve your problem,regarding with the socket 478 intel pentium 4 prices.But ii think it s hard for you to fine the brand new one of intel pentium 4,coz right now,i can offer is more on surplus,its 1300.But selecting pentium 4 motherboards depend on what processor u have,coz we have to consider first its compatibility.tnx
Aug 17, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
What kind of cpu do i need ? i have asus p5nd2-sli motherboard with no cpu in it
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Seems that you need Socket LGA775,and CPU: Pentium 4, CeleronD, Pentium D, Pentium Extreme Edition. For more Details go here:
http://www.google.com/products/catalog?hl=en&q=p5nd2-sli+motherboard&cid=13414569805758042878&os=tech-specs
Nov 16, 2010 | ASUS P5ND2-SLI Deluxe Motherboard
Pentium 4 motherbord socket 7 edo ram memory
P-IV system boards probably don't come in socket 7..
if however so, it may b a hybrid-board..
normally socket-7 is for P-II's..
well, wat do wanna know..??..
seek professional advise of ur system admin/vendor....
Nov 18, 2009 | Computers & Internet
About mainboard or motherboard
Sometimes. Both the Pentium, Pentium II, many AMD, and some Cyrix processors used a socket 7. So depending on your motherboard and what two processors you are using it may work.
May 23, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
SY-6IWM motherboard
Your motherboard is a slot 1 socket board that is Pentium II, Pentium III and Celeron compatible.
Jan 29, 2009 | Soyo Slot 1 SY-6IWM/L Motherboard
Upgrading IBM ThinkPad T20 Intel Pentium III to Intel Pentium 4
Patrick, I'm glad to see your enthusiasm to explore and expand on your computer knowledge. Unfortunately I have to be the first to let you know that in this case your ideas on upgrading your systems by simply changing the processors just won't work.
First of all a Pentium 4 (or Centrino, which is the mobile version) literally will not fit into any of the systems you mention. All CPUs are made in specific form factors to fit into different sockets. Most Pentium 4 processors were made for Socket 478 or 478B sockets, which mean they have 478 pins on a chip roughly an inch and a quarter square. The high number of pins allow more signals and data to be passed simultaneously to the motherboard, one way the speed of the CPU operations were increased. Pentium III and older Celerons were mainly socket 370 chips on a chip almost an inch and three quarters square. The lesser number of pins were aligned in six concentric rows with a blank central square. Pentium II and even older Celerons used Socket 7 and any of a half dozen other schemes and were often put on daughtercards to make them somewhat interchangeable. It would be like trying to put a square peg in a round hole.
They also make other forms, like socket 775, 939, and the newest AM2, all of which are pin-incompatible. In certain situations there are adapters that will let you put a newer CPU into an older socket but the specific upgrades you mention have no equivalent.
There are other engineering factors to be considered as well. Not all CPUs run on the same voltage. Many desktop motherboards have been designed that are adjustable either by selecting the operating speed with jumpers (old style) or by electrically sensing the optimum speed of the CPU. Then there are the memory and bus speeds. The CPU has to be able to interact with the memory so they must share a signal speed. This is the Front Side Bus. Older Pentium 4 CPUs were designed to use PC-133 memory but more powerful CPUs. certainly any in the 2.0GHz and up range, are designed for Double Data Rate (DDR), which is PC-2100 up to PC-3200. The pin configuration of the memory is different also to reflect and optimize the faster design. Of course there is now a DDR2 design and most recently DDR3. Core-Duos and Quads use the DDR2 and DDR3 type memory.
Another factor is heat. Faster CPUs run hotter. the system must be designed to accomodate and release the greater amount of heat generated, thus there are larger heatsinks and fans and more vent holes. Otherwise the CPU would start acting erratically and eventually burn out.
Things would be slightly different if you were talking AMD chips, as the socket 472 was much more versitile and could handle a wider range of CPUs and speed, from Duron to Sempron to Athlon XP, all because of the way AMD designed their chips. Of course, they too had to upgrade to surpass physical limitations, leading to the socket 754 and other newer designs.
Desktop machines are much more flexible to upgrade because of the space available and the fact they are designed with expansion slots. If you need a higher video card to run games, or more com ports to run extra printers or whatever, you can generally place a card in a slot to add the functionality. If you reach the design limits of a motherboard you can usually swap it out. Not so with laptops.
Laptops in particular are hard to upgrade because everything is integrated into or designed to plug into the motherboard, which has to fit the case properly like a jigsaw puzzle. This is not to say it is impossible to upgrade somewhat, but usually for laptops it means putting a faster CPU of the same form. Here is an example that is specifically for the IBM T40 laptop:
http://bsnugroho.com/t40upgrade.aspx
No, if you want to upgrade to Pentium 4 or Core Duo or Core Quad speed and performance, you will have to go out and buy a laptop.
Please do not let this discourage your enthusiasm. You share the spirit of the old school to push the limits that has made all of these computer evolutions possible. Consider formal training to round out your knowledge and to expose you to more within the field.
Dec 31, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Upgrade the processor.
More important is the question of what processors can your motherboard handle. Certain motherboards accept certain sockets and speeds of processor, so you can choose from that to decide what you want to upgrade it with.
See page 8 of this manual. Your compuer has a Socket 370 processor, an Intel Pentium II. You can upgrade it with another one of those. Here's the manual listing the specs of the processor the motherboard can take:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/lpv06683/lpv06683.pdf
Yikes, a Pentium II?? Unfortunately it will definately be more economical to just replace the whole motherboard, or the whole computer! This motherboard will only support a range of P2 processors, an upgrade will cost several hundred dollars, close to the price of a brand new computer with a P4 in it.
Feb 05, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Motherbooard for Compaq Presario sr1050nx
A7 indicates that it is a K7 series - a socket 462. Socket 7's were for the old Pentium 1's and AMD K5, and K6 I,II, and III series of pre-athalon processors. Socket 7 was also the last socket to see Cyrix chips.
Oct 15, 2006 | Compaq Presario SR1050NX (DW257A) PC...
Intel Motherboard Logo
122 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
