Question about Dishwashers
Maytag MJD 3000 AAW Dishwasher Keeps stopping with E3 error. Manual says heater problem or filter mesh blocked. Filter is clear. Does full cycle OK sometimes. Does not have problem on all cycles ie quick wash is OK.
  • Anonymous Jun 02, 2008
    Same problem with the E3 error.  Repairer changed motor but still not fixed.  Returned to say main board now broken.
  • Anonymous Mar 23, 2009
    Maytag MJD 2000 AAW stalls with E3 error. Filter is clean.
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Maytag jetclean Model number MJD
Cause: The water heater element does not work properly or the filter mesh is blocked.
Remedy: Clean the filter mesh and if the problem continues, the main board needs to be replaced.
The Filter mesh in the bottom of the appliance.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 14, 2011
My fontloader samsung wassingmachene p843 giv me and error code e3 4e and5e
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 22, 2012 | Washing Machines
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal -0- what does mean that error code?
check fluff filter usually in the door is clear, it can be that it is overheating due to lack of air as the fluff filter is full. also check air escape pipe is clear and not blocked or folded.
I hope this was useful.
Oct 20, 2012 | Dryers
My washin machine is just stopping thru cycles and beeping continuously until I switch off - reading E3. My father thinks it might be the heater, is that right. I'm having a lot of trouble getting...
Hi, the E3 error is comes up when the water heater element does not work properly or the filter mesh is blocked. Remedy: Clean the filter mesh and if the problem continues, the main board needs to be replaced.
Jun 24, 2011 | Maytag 24 in. MDB6600A Jetclean II...
We have a Matage dishwasher Model MJD.3000AAW. There is an error message: E4. What do we need to do?
Hi, the E4 error means the water heater element does not work properly or the filter mesh is blocked. Most likely the heating element burned out/thermal fuse or Clean the filter mesh to resolve the problem.
Jun 22, 2011 | Maytag Dishwasher
Maytag jetclean Model number MJD 3000 AAW Problem : E3 error towards end of cycle
Hope i helped you.
Jun 14, 2011 | Dishwashers
I would like to get a manual/guidefor dishwasher DW009H from B&Q . Drying does not seem to be very thorough at the end of the cycle. Also the code E3 is showing when finished.
E3 Error Code
Remedy: Clean the filter mesh and if the problem continues please contact service
As far as a manual is concerned, I believe Hobart manufacturers your model and not B&Q. B&Q just sells the unit. You may want to locate a Hobart dealer in your location to try to get the manual. You will probably need one to fix the heater element any how.
Jun 05, 2011 | Dishwashers
I have a Maytag MAH-24 that is giving me an E3 error.
E3
Mar 14, 2010 | Washing Machines
It quits and gives the e3 when it has a full load but will work fine on a small load like 3 shirts and one short any ideas
E3
Mar 02, 2010 | Maytag Neptune Washer
I am looking for an instruction guide booklet
sorry but my sites arent finding a model mjd2000aaw. www.maytag there is section for cumsumer support wher eyou can download your manual with model info
Dec 02, 2008 | Maytag Dishwashers
Dishwashers Logo
331 people viewed this question
Top Dishwashers Experts
