Projection television i got a mitsubishi widesceen that i haven't able to turn it on . the poblem is at folllows : when i push power bottom on the on the TV or TV remonte control, only sound a click once and a click back but nothing pops up on screen (all black ) the indicator light turns on and off inmediatley . i pushed reset bottom but still the same ,disconect from power outlet and reconected and the same problem. the wide screen is a mitsubishi 55" model ws 55511 serial number 113643 manufaturer date : NOV 2002 .
  • 2 more comments
  • bywed Apr 30, 2008
    but where exactly can i start to look for a loose wire ? ...i don't know anything about this electronics
    i don't have any warranty on this TV now; so i will open it , but some place in special that should put more attention on the wiring ?
  • bywed May 02, 2008
    i checked all and everything seems to be ok , any wire loose or anything ,something else that it can be the problem ?
  • bywed May 03, 2008
    so ..do i have to replace the main board completely ?
    Genius:
  • 1,447 Answers
Loose wires or damaged contacts might be the problem, suggesting to call manufacturer for service support and for a servicer in your area.
Posted on Apr 29, 2008
  • 2 more comments
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 30, 2008
    You can take the risk of opening the back portion of your television and check for wirings but if TV is still within warranty you might void it if you'll open it up.
    convergence ic chips, capasitors, resistors, and main boards as well.
    Edgar Allan Pagayona May 02, 2008
    Yep it might be the main board
    Edgar Allan Pagayona May 03, 2008
    sorry to say, but you might have to change it. call a servicer and ask for an estimation instead so that you can compare buying a new one or have i t service. good day!!
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi vs-60803 turns relay on board then goes
replace the power relay the contacts are burned and, will not latch.
Jul 22, 2010 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi TV Screen Water Stain Problem
You can use warm water and a soft cloth to try and clean it, but it will probably leave some evidence that liquid existed between the two layers at some point. Mitsubishi will deal screens directly to their customers if you ask nice enough and are willing to install yourself.
Jul 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Tv poblem
if it were my tv i would call a tv repairman.sometimes the repairs are simple other times they can be complicated,,,the power inverter could be out or it could be somethng much simpler.
Jan 24, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Philips 55" tv
Yes I've had to replaced mine twice. here is the best price I found the second time I ordered it only $99.00.
http://www.intl-lighttech.com/store/item_GTL-OS-69374
May 15, 2008 | Philips 55PL9773 55" Rear Projection...
Set won't turn on
I would check the convergence output IC`s first.
Sep 27, 2006 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
