Question about ITT Night Mariner 160 Monocular
ITT night mariner 160
We had not used this for several years.  After changing the batteries, it still does not work.  Any special installation techniques for the batteries? Are there other batteries than the 4 AAA batteries?
  • 22 Answers
My advice ,if i were you, would be to leave the batteries in for a day and leave your unit turned on. either leave the cap on, or put it in a closet and see if it works better. The new AAA batteries should be fine i'm sure you have how to put the four in correct, and yes they are all that's needed. But leaving your unit on for the day will do a few things. First, it puts a current through all of the working components, i.e. light gathering elements and your infrared components. They may "wake up" from being on and they may not. But at the very worst you are only out the cost of four triple A's.
Posted on May 06, 2008
Although several years old, my Norelco 6826XL has very little actual use time...probably less than one hour. Recently, it failed to work. Even when the charging cord is plugged in, there is absolutely no...
The batteries have probably gone bad from age. If they have not corroded and caused damage to the internal pats, you should be able to change them to get it going again
You will find the correct battery type for model 7864XL at See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have do it for you. See link below
Apr 01, 2011 | Norelco Quadra 6826 XL Electric Shaver
How to optimize your Laptop Battery
Now the main problem that comes with most laptop users is the backup ThinkPad x41 battery that provides. Many of the laptops that are on the market are good enough to give you the maximum life of the battery, but this is not the case with most brands.
Here are some things or basic tips you should follow to make your Dell latitude d610 battery gives you the most time Backup.
1. First go for the clean bill of health or life of the battery. This can be done by having the software installed on your laptop that constantly monitors your Dell XPS M1710 battery and give you feedback. The Most of these programs are freeware or are incorporated with the installation disc factory. This will help you to have proper control of C1295 battery life if it can achieve the desired power or not.
2. Never attempt to manually remove and short inspiron 600m battery runs out. This will allow your battery discharge quite a while to leave the damaged battery case severe rejection. These are the most dangerous conditions and should be avoided.
3. Never discharge the Dell latitude x200 battery before connecting the power supply, because it will shorten the battery life too. Discharge completely and then charging it must always be avoided.
4. The next thing could do to save battery is to opt for the option to hibernate the laptop. This is especially useful for laptop in case of battery saving techniques.
Always follow the techniques mentioned above to make your laptop work very well give you the Backup Maximum Vostro 1500 battery life with most of the battery too.
on Oct 11, 2010 | Computers & Internet
:( the phone got reset and its struck with the screen... i cant tap it help me out
One thing that you can do to try to resolve this issue is to take the battery out while the phone is on. This is called a hard shock and will not damage the device. I was a tech trainer for at&t for several years and this is a common troubleshooting technique. If this does not work and the device is under a year old, I would advise you to contact your wireless provider as the handset is under a 1 year warranty from the manufacturer and they will usually replace it at no cost. The down side is that you will lose all of your pictures, games and ringtones if you have any. I hope that you have found this information useful as that is my goal.
Jan 18, 2011 | Samsung SGH-A877 Impression Cell Phone
Hello there,........i have a samsung digimax s500cyber530 that i bought appox: 4 years ago?,.....and we just several days ago replaced an 8 year old gateway "windows" computer w/a brand new HP...
Once you get the camera working again by the "shuffling technique", don't connect it to the computer again. Instead, purchase an inexpensive card reader and use it to download pictures from now on. typrice_31.jpg
Nov 17, 2010 | Samsung Digimax 530 Digital Camera
Why my 28v doesn't fully charge. when charging indicator light is red. there is 4 charge indicator. when it reach 2 green light comes on showing fully charged. you would use it for about 20 minutes and...
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
Nov 26, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
My RCA HDTV remote won't work with the regular tv. It was working fine last night until i pressed the tv botton and the volume button.
One thing you can try is to take the batteries out of the remote and then press every button on the remote, then replace the batteries. I have used this technique several times and it works. If that doesn't help try leaving the batteries out over night, this may reset the remote.
I hope this helps.
Aug 01, 2009 | RCA HD52W59 HDTV Projection Television
DFT technique in image steganography
Just do a search in your favorite search engine for 'steganography dft' and you should get several thousand results that cover the theory, the math involved, etc. Bing returned 3,380 valid results.
Jul 26, 2009 | Computers & Internet
Cordless trackman will no longer work after update.
Do a system restore back to before you did the update.
See if that works--it should, as you seem to have pointed to the time that it stopped working.
You didn't say what technique that you used to fix it before, but this should work.
You can also go into the control panel and see if you have, in fact, designated this device to be your mouse. I have run into several systems that, when I went into the control panel and looked at the mouse that it thought was installed, it seemed to have changed. You'll need to set it back to what you want.
Jun 03, 2009 | Logitech Cordless TrackMan Optical...
I think i can see the fuel pump!
it is inside the tank and no special tools are needed no special techniques there is a hose where you put the gas in at and remove the straps below is the steps I follow when changing the pump: first you put rearend on jack stands secure the frontend so it does not roll place a floor jack with a piece of board (to keep from putting a hole in the tank) under the tank remove the screws and nuts lower tank using the floor jack and board be careful not to break any wires at the top of the tank remove the center ring from the top and there is the fuel pump
Mar 22, 2009 | 1992 Chevrolet Cavalier
ITT Night Mariner 160 Monocular Logo
267 people viewed this question
Top ITT Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an ITT Optic Expert? Answer questions, earn points and help others
