posted by Steinmonkey on Apr 29, 2008
Hi I have 17 numbers programmed in with the business names. All is working fine but my boss wants me to change the ID numbers. For example, the first is #001, he wants me to change it to #021. Is this possible? If so, how? If not, how can I delete #001-#017?
Thank you so much.
Jayne
Best Solution
posted on May 28, 2008
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother IntelliFax-2820 Plain Paper
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Brother IntelliFax-2820 Plain Paper Laser Fax
Paper jam will not go
Paper jam will not go away Answer This...
Can I use the all in one phone...
I have a MFC-665CW, I am... Answer This...
INTELLIFAX 2820--PAPER/SCANNER...
thx for prompt reply... Answer This...
not connecting to fax out
The fax machine recieves faxes... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
