Question about Microsoft Wireless IntelliMouse Explorer
Microsoft wireless intelimouse explorer 2.0
Right mouse click function stopped working. Other functions work OK. Replacing batteries did not help. Any ideas to fix or should I replace 2 year old mouse?
  • 7 more comments
  • bigreddog22 Jul 18, 2008
    right click stopped working for me also
  • Anonymous Aug 28, 2008
    Same here. Was a good mouse and I'm unable to find anything similar to replace it that I am comfortable with.
  • morley405 Oct 20, 2008
    Same here.. No right click & it is always asking for new batteries. Is it kaput???
  • rwomack Nov 06, 2008
    Sounds like a defect in workmanship as I have the same issue too. maybe Microsoft would be willing to replace it if written a letter.
  • Anonymous Nov 28, 2008
    right click button will no longer work
  • Anonymous Jan 14, 2009
    I got the same anyoing problem. Seems like the clicking thing on the printboard stopped working correctly. Only if I push hard it still works.
  • Anonymous Feb 19, 2009
    same problem , right click stop working :(
  • Anonymous Mar 28, 2009
    had the same problem, followed the tip to dissassemble and clean and the problem was solved.
  • Anonymous Mar 27, 2014
    I cleared my Java cache now my Microsoft wireless keyboard won't work. Can't type in the password to get back on. The function key won't light up but the mouse appears to be working.
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Posted on Feb 23, 2009
  • lindawoodwar
    lindawoodwar Jan 11, 2013
    Your instrutions worked!! Thank you SO much! I had cat hair around the wheel so had to use a toothbrush to dislodge & tweezers to pull it out. Otherwise, did exactly as you instructed and my Logitech is WORKING again--copy & paste.
The right button wore out on my wireless intellimouse explorer 2.
Time for a new mouse, but in the mean time, I reset the side button to right-click.
Posted on Jan 24, 2009
    President:
  • 8,637 Answers
Go to Control Panel and click on the mouse icon. When the window opens select the right mouse button and make sure it is not disabled.
Hope this helps. Bud
Posted on Jan 20, 2009
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
Oct 31, 2010 | HP Wireless Optical Mouse
Right click malfunction
Do you have the mouse driver installed that came on the CD? Without the correct driver, all of the functions may not work correctly.
If you go into the mouse properties in the Control Panel, you can select the function for the right button. See what the function is currently set for and try to change it and see if anything happens.
Jun 06, 2010 | Microsoft Wireless Laser Desktop 4000...
My Microsoft Bluetooth Mouse will not stay connected to my system
1. Go to Start->Run and type in "services.msc" and click OK
2. Find "Bluetooth Support Service" in the list of services and double click to open the properties window
3. Click on the "Log On" tab and select "Local System Account" for "Log on as:"
4. Click Apply and OK
5. Right click on "Bluetooth Support Service" and select stop then right click on "Bluetooth Support Service" again and select start
6. You may need to reconnect your bluetooth devices; everything should be working now.
Nov 18, 2009 | Microsoft IntelliMouse Explorer Bluetooth...
Microsoft Wireless IntelliMouse Explorer 2.0 - low battery pop up
I would disregard the pop up as in most cases the batteries are still good. I'd use the mouse till it stopped functioning. Why it does that I haven't figured out yet. I beleive a value has to be changed in the Registry. If I figure it out I will let you know.
Bud
Jan 22, 2009 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Jan 02, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
I unplugged the "adapter" (not sure that is the right word) from the computer and then realized it was the connector for my wireless Microsoft InteliMouse Explorer 2.0 Model 1007 and I now can not get it...
Try unplugging the Mouse again, then take the Power Lead out the back of the PC, and leave it to stand for a few mins atleast. Then plug the USB Mouse back in, plug the Power Lead back into back of PC and Boot Up. That should work for you.
Dec 05, 2008 | Microsoft Wireless Optical Mouse
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless IntelliMouse Explorer 2.0 problems
Make sure the batteries are good and try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Mar 02, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless IntelliMouse Explorer Logo
1,180 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
