Question about Rockford Fosgate P3001 Car Audio Amplifier
Punch Amp Could you please tell me if there is an adapter to connect a p300-1 punch amp to a factory 2001 Silverado and it is currently connected to an ipod via isimple ipod interface for a factory radio, and has no rca jacks. Thank you
  • 631 Answers
A Line Output Converter (LOC) is the cheapest, simplest option. You should be able to get one at any of the local car audio shops.
Posted on Apr 30, 2008
I hooked up a punch 250 a2 amp the l.e.d came on with no problem then i turned the car on and the amp smoked a little bit did i blow the amp the l.e.d still was on i just unhooked quickly to be safe
Hopefully you havent blown the amp, check ALL of the wiring, make sure that your earth connection is connected to a clean metal area and make sure that the power cable you are using is big enough for the job. The Punch range of amps require a fair bit of power. skinny power cables wont help your situation and if too thin, then the amount of current could melt the plastic casing could cause a fire.
May 06, 2011 | Car Audio & Video
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
How do you install an amp in new cars when the factory radio is basically an computer and doesn't come out of the dash?
You need to use a Hi Low Converter. They have a different name but I cant think of it right now. Basically it connects to your rear speaker and converts it to RCA connectors that you could connect to your amp. Then connect your amp to power (battery) and Ground to power it up. Last thing to do is connect yours speakers to the amp.
Also get a high Low converter with remote connection.
Apr 22, 2010 | Rockford Fosgate Punch P3002 Car Audio...
Rockford Fosgate Punch 500a amp wont turn on
check the internal fuses inside the amp its self these burn up real easy plus if it is them it will save you some money
Mar 31, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
Power and ground are good cant get amp to turn on
Don't forget the most inportant one, the remote wire!!!! It tells the amp when to turn on/off. Should be connected to your aftermarket radio amp or power anteanna lead (should be blue). If running a factory radio you can use the radio fuse power to provide a signal to it..
Oct 26, 2009 | Rockford Fosgate Punch 120.2 Car Audio...
I am trying to install a amp and sub in my 08 gmc
dont need a diagram,, most amps have a speaker level input...dont mix this up with line level....connect your wires from back of factory speakers to speaker level input on amp...then if your amp has a low pass switch select lowpass setting now you have punch
Mar 29, 2009 | 2008 GMC Sierra 1500
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Amp arc
What you need to do is first ground your amplifier securely then make sure all connections are fastened. don't remove the speaker connection and listen for sound. If there is no sound power down the unit, and send it to a repair shop because it sound like you may have damaged some components in the unit. But in order to come to this point you have to make sure you ground the unit properly and then make sure all of your connections are secure. Contact me once this is done and you are ready to do some tests.
Aug 28, 2007 | Rockford Fosgate Punch P5002 Car Audio...
No power
hi, some car amps need a high current remote supply to turn on. first make sure that you are using the proper gauge b+ and gnd cable for this particular rockford amp. then try switching the remtote turn on to this amp thru a simple Relay.(use the remote supply from your headunit as a trigger for the relay). do these connections without connecting any spks or rca line inputs. once amp is switching on then connect all other cables. OR lastly check the main fuse on the RF amp?? cheers
Jul 22, 2007 | Rockford Fosgate Punch P325.2 2-Channel...
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Rockford Fosgate P3001 Car Audio Amplifier Logo
102 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
